Joel8033 Posted April 4, 2020 Report Share Posted April 4, 2020 Dodge journey sxt the ac quit working after I changed the plugs. I've went through and made sure everything is plugged back up.. but the compressor wont kick on.. I cant find a fuse or relay.. is there one?? I'd like to check this before I buy a new compressor.. thanks any advice would help Quote Link to comment Share on other sites More sharing options...
larryl Posted April 4, 2020 Report Share Posted April 4, 2020 Was the Compressor working before you changed the plugs? Cant see how they can be related? OhareFred 1 Quote Link to comment Share on other sites More sharing options...
probak118 Posted April 5, 2020 Report Share Posted April 5, 2020 Take whatever you had to remove to change the plugs again. Maybe you will see if you disconnected some wire and it is just lying there ? OhareFred, 2late4u and jkeaton 1 2 Quote Link to comment Share on other sites More sharing options...
