livinalie85 Posted April 9, 2020 Report Share Posted April 9, 2020 this was something that would happen just randomly but is happeing more and more often. starts off with the grinding sound/feel like like my ABS system is activating as if i were to slam on my breaks, but im just applying the breaks normally. after a while the ABS, Service all wheel drive, and traction control lights all come on at the same time. the grinding stops after that. Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted April 9, 2020 Official Dodge Support Report Share Posted April 9, 2020 1 hour ago, livinalie85 said: this was something that would happen just randomly but is happeing more and more often. starts off with the grinding sound/feel like like my ABS system is activating as if i were to slam on my breaks, but im just applying the breaks normally. after a while the ABS, Service all wheel drive, and traction control lights all come on at the same time. the grinding stops after that. Hello livinalie85, If you decide to have your vehicle diagnosed and you feel that additional assistance is needed, please feel free to send us a direct message. We'd be glad to help. Lamar DodgeCares Quote Link to comment Share on other sites More sharing options...
John/Horace Posted April 10, 2020 Report Share Posted April 10, 2020 Probably not grinding, abs pump cycling on and off. Scan for codes always a good starting point. Even an intermittent issue will often store codes. Quote Link to comment Share on other sites More sharing options...
