Pres Posted April 10, 2020 Report Share Posted April 10, 2020 The belt on my 2012 Journey CVP Model 2.4L keeps slipping off the pulley resulting in either falling completely off onto the side of the road, or shredding an entire rib before falling off. I Bought brand new and replaced the lower idler, upper idler, the tensioner, and the Serpentine belt but the issue still remains. Does anyone have similar issues and possible solutions as to what may be the cause of the problem? Thanks kindly. Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 10, 2020 Report Share Posted April 10, 2020 looks like you have covered all the possibility on parts make sure everything is in line also check your alternator and the decouple pulley as well if it starts dragging that could cause the belt to slip and or heat up and come off also as well the ac compressor pulley,good luck Quote Link to comment Share on other sites More sharing options...
Pres Posted April 10, 2020 Author Report Share Posted April 10, 2020 2 minutes ago, 2late4u said: looks like you have covered all the possibility on parts make sure everything is in line also check your alternator and the decouple pulley as well if it starts dragging that could cause the belt to slip and or heat up and come off also as well the ac compressor pulley,good luck Quote Link to comment Share on other sites More sharing options...
Pres Posted April 10, 2020 Author Report Share Posted April 10, 2020 I’ll try those next and update my post whenever I get around to it. Maybe next weekend. Thanks a lot man. Quote Link to comment Share on other sites More sharing options...
