wpginterceptor Posted May 16, 2020 Report Share Posted May 16, 2020 (edited) REMEMBER.. you cannot use any other washer fluid other than the blue stuff.. if you use the yellow stuff the washer fluid detection sensor cannot detect it and will show low washer fluid warning light on dash!! EVEN WHEN THE JUG IS FULL!!! Edited May 16, 2020 by wpginterceptor OhareFred 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 16, 2020 Report Share Posted May 16, 2020 i have a 2014 crossroad and i only use rain X the pink washer fluid (winter time) that way dont have to worry about switching over before winter time and have never had any problems with my light coming on unless it gets low OhareFred 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted May 16, 2020 Report Share Posted May 16, 2020 I use purple stuff year round on my 09. Never had any issue 2late4u 1 Quote Link to comment Share on other sites More sharing options...
probak118 Posted May 17, 2020 Report Share Posted May 17, 2020 Use what ever is the best deal at that time what ever colour or brand.....colour changes as fluids are mixed.. But then again I never let the washer fluid get to that point of low level warning ! OhareFred 1 Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted May 17, 2020 Author Report Share Posted May 17, 2020 no what im saying is.. if you use the yellow Teflon stuff. it screws with the low level warning sensor inside the washer jug on the car and shows low washer light on the dash.. even though the jug is full!! Drain the yellow put the blue back in and bam the light goes off! Quote Link to comment Share on other sites More sharing options...
probak118 Posted May 18, 2020 Report Share Posted May 18, 2020 On 5/16/2020 at 7:56 PM, 2late4u said: i have a 2014 crossroad and i only use rain X the pink washer fluid (winter time) that way dont have to worry about switching over before winter time and have never had any problems with my light coming on unless it gets low Expand So why does 2late4u not have an issue, would the yellow rainX not also have teflon type additives in it in order to repel the water ? You're not the only person using these type washer fluids I bet, this is the first I've read about this issue here. These are not new products, is it possible the sensor is just getting weaker over time and this type product affects it more ? Like you said, when using blue fluid issue gone, use the blue problem solved. I am going to add some rainx to my washer fluid resevoir now and see what happens. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted May 18, 2020 Report Share Posted May 18, 2020 (edited) It’s not a conductivity probe I believe, just a simple float. Buoyancy could very slightly with alcohol content versus straight water but I doubt it changes trigger point enough to be noticeable. You probably have a flaky probe. Only issue I have with my system is passenger side hood sprayer fell apart. Pricy piece of plastic. Previous owner probably used water as some point. Edited May 18, 2020 by John/Horace Quote Link to comment Share on other sites More sharing options...
probak118 Posted May 22, 2020 Report Share Posted May 22, 2020 Its been four days now since I added 4 oz of rain-X to my washer fluid reservoir.( rain-x website instructions for adding to washer fluid)...no low fluid level alarm yet ? If my windshield beads water better may just keep doing this, unless my low level light suddenly starts coming on . Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted June 3, 2020 Author Report Share Posted June 3, 2020 On 5/22/2020 at 10:36 AM, probak118 said: Its been four days now since I added 4 oz of rain-X to my washer fluid reservoir.( rain-x website instructions for adding to washer fluid)...no low fluid level alarm yet ? If my windshield beads water better may just keep doing this, unless my low level light suddenly starts coming on . Expand mine took a while to start acting up.. went away though right after I put the glue stuff back in Quote Link to comment Share on other sites More sharing options...
Jimmy U Posted January 11, 2022 Report Share Posted January 11, 2022 Hi, I am just new guy. I thought I make a comment on these, I have 2016 Dodge Journey 2.4l engine, Jan 10, 2022 While driving my windshield washer fluid lights on and I just filled up the tank and Yes I used the Yellow stuff not going to mention the name, and my tank originally have the blue color washer fluid, so I searched on the internet and I came across on these forum, first thing I saw was @wpginterceptor suggestion but I red the whole thread but what could go wrong if I will try what he said so I decided to follow @wpginterceptor tips. just today January 11, 2022 but before that while driving to CanadianTire lights came on again, after buying not blue but close it's like Bleu to Green colour, emptied washer tank and refill it with the new washer liquid like I said not exactly blue but close, blue to almost green, GUESS WHAT THE LIGHTS DID NOT CAME OUT after driving same distance from CT to Home, now I am not saying these technique will work for all, just saying it worked for me. Thanks to @wpginterceptor I will keep observing and update you guys and see how these Yellow liquid really creating problem with washer sensor and if my problem solve. Thanks all for suggestions and tips Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 11, 2022 Report Share Posted January 11, 2022 hmm kind of weird. my 2014 washer squirters work great with any kind or color fluid ive used but the pink rain x the most as wally mart always usually runs it on clearance after the winter time is over so i always buy it lots of it cheap John/Horace 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted January 12, 2022 Report Share Posted January 12, 2022 I've had no issue with the Costco fluid Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 12, 2022 Report Share Posted January 12, 2022 (edited) actual part cost is less than $5. Orileys part store,,,, not sure how hard to replace on our journeys ,any one having a problem might want to try this first Edited January 12, 2022 by 2late4u John/Horace 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted January 12, 2022 Report Share Posted January 12, 2022 (edited) This is what he was cleaning, very clever fix actually. Probably have to drain and remove jug to change part. Cleaning seems easier, just don’t use wife’s tooth brush; too cold to sleep in garage this time of year.? Edited January 12, 2022 by John/Horace jkeaton and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted January 24, 2022 Author Report Share Posted January 24, 2022 my sensor is fine since I went back to the Blue washer fluid Quote Link to comment Share on other sites More sharing options...
John/Horace Posted January 24, 2022 Report Share Posted January 24, 2022 I use the green normally. Cheap from Costco by the case. If you flush out tank in summer you might be able to use the pricy rainX stuff. Like they are saying, must be some kind of crud on the sensor that affects signal from sensor. The fix seemed to make sense. Can’t imagine Stelantis FCA selling a car with a system that doesn’t accept all windshield wiper fluid. The low level light on my wife’s Journey has never come on. Not sure it even works. I’ll need to run it low and see. Quote Link to comment Share on other sites More sharing options...
NRG Posted January 18 Report Share Posted January 18 Not gonna lie....I laughed when I found this thread while researching my own issue with the washer low light coming on in my 2017 GT. I didn't think it was possible but after replacing the yellow rainx stuff my husband put in with the blue stuff I made him buy to humor me I'm laughing at how simple this fix was. No light now! This is the funniest fix I've ever come across. I can't stop laughing when I think about it larryl, John/Horace and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
