jkeaton Posted May 20, 2020 Report Share Posted May 20, 2020 Figured I'd throw this out there for the DIY'rs. Harbor Freight has recalled their 3 ton jack stands. Be careful if you are still using them. https://www.cnet.com/roadshow/news/harbor-freight-recall-jackstands-collapse/ John/Horace, NavalLacrosse and 2late4u 1 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 20, 2020 Report Share Posted May 20, 2020 i had just seen this as well,dont have this kind mine are the old ones that have a long pin or bolt that you have to insert thur the hole to hold the jack in place,but all my years even when using them i still dont remove the jack i always just release enough weight onto the jack stands and then set the floor jack with enough pressure on it just in case... Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 20, 2020 Author Report Share Posted May 20, 2020 1 hour ago, 2late4u said: i had just seen this as well,dont have this kind mine are the old ones that have a long pin or bolt that you have to insert thur the hole to hold the jack in place,but all my years even when using them i still dont remove the jack i always just release enough weight onto the jack stands and then set the floor jack with enough pressure on it just in case... Same here. I just cant bring myself to trust jack stands by themselves. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Airtray Posted June 7, 2020 Report Share Posted June 7, 2020 Brought mine back to HF last week, no receipt and no problem. In and out with a gift card (tax incl) in less than 5 minutes. Quote Link to comment Share on other sites More sharing options...
NavalLacrosse Posted June 8, 2020 Report Share Posted June 8, 2020 I have the exact ones they are recalling. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 8, 2020 Author Report Share Posted June 8, 2020 11 hours ago, NavalLacrosse said: I have the exact ones they are recalling. Hope you don't use them anymore and go get another set. Quote Link to comment Share on other sites More sharing options...
