Engine replacement 3.5l
MoNab
Has anyone replaced the engine on a 2010 3.5l awd. My current engine has a bad head gasket so I just want to replace the whole engine. Does anyone have a service manual or steps on how to do it? Thanks, much appreciated.
Just did this on an 09 and about to re do it as I don't have compression on one side of the engine, but that's another story.
I have yet to do the write up but will post soon. Pretty simple. Torque wrench, 3/8 and 1/4 ratchets. 8, 10, 13, 15, 16, and I believe an 18 and/or 19mm socket (shallow and deep for all is helpful along with 1"-8" extensions. Youll need 10, 13, and 15 wrenches. Pliers for hose clamps. And depending on your approach to the cams a 31 or 34mm wrench or the special holding tool. If you can weld or have a drill it's easy to make. Basically a two post spanner wrench. Pm me if you'd like pics/video
Oh and a 6 point "E" type socket. E30? I'd have to check, but a 12point 3/8 socket works well too.
Edited by Borjawil
