Sounds like a bad bearing
I am having an issue with my journey. I have a sound that sounds like a bearing going bad. I have had both front bearings, axel shafts and the transmission replaced. The tires have less than 25,000 on them. I’m at a loss. It has been suggested to me that I could have an unbalanced drive shaft due to a rear end accident two years ago. It has also been suggested that perhaps I have bad wheel spacers. Has anyone else had this issue?
Edited by Hcaron
Misspelling
The sound only happens while driving and gets louder when I slow down. Brakes and rotors have been checked and they are fine also. As for the the wheel spacers theory, I was told that some model years come from the factory with these on the wheels. I’ve not heard of that before so, I don’t really know.
If you can,  remove the wheel spacers. They tend to wear out bearings and it’s better not to have them if possible.
How many miles on car?  Some mechanics have listening device to trouble shoot bearings etc.
Rear driveshaft on awd vehicles can often be removed temporarily  to prove if that’s the cause, pricy item to replace.
I drove my grand Cherokee for its last two years without rear drive shaft, $1000 viscous coupling repair couldn’t be justified.
Removing driveshaft was a 15 minute one wrench only job.
There is one changeable part on driveshaft.
https://www.rockauto.com/en/catalog/dodge,2014,journey,3.6l+v6,3300354,drivetrain,drive+shaft+flex+joint,10701
Edited by John/Horace
