Kblyk19 Posted June 16, 2020 Report Share Posted June 16, 2020 I have a 2010 Dodge journey that will randomly beep it will be like one beep just random and it’s when my car has been off no windows are down no doors are open the car is locked but when it beeps my wiper blades jump so I know how many times it beeps throughout the night because my wiper blades will move with each beep. the previous owner had a aftermarket alarm system but I don’t use it I use the one that came with the car can someone give me any idea. It’s just one beep. Once in a while. jose laprovitera 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted June 16, 2020 Report Share Posted June 16, 2020 Look for the aftermarket alarm under the dash and pull the main plug. I think two systems are interfering with each other. Hood has a small switch on passenger side fender that is made when hood is closed. Make sure it is being fully depressed. Could even check continuity on switch with multi meter. Shim it if needed. Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
Kblyk19 Posted June 17, 2020 Author Report Share Posted June 17, 2020 Where are aftermarkets normally installed? I just want to make it stop. Lol I love my car and this is the only down fall Quote Link to comment Share on other sites More sharing options...
OhareFred Posted June 18, 2020 Report Share Posted June 18, 2020 Car stereo shops, Best Buy, peoples garages. Quote Link to comment Share on other sites More sharing options...
Kblyk19 Posted June 18, 2020 Author Report Share Posted June 18, 2020 I don’t want to buy one. I have one. I’m trying to see where people normally install them in the car. So I can take the aftermarket one out OhareFred 1 Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted June 18, 2020 Report Share Posted June 18, 2020 Here is a general guide to car alarms that may help you locate components. The easiest way to disable the alarm is disconnecting the power source or a kill switch. Perhaps it's worth taking to a local shop and having them disconnect it. It would be far quicker and likely not that costly. https://www.wikihow.com/Install-a-Car-Alarm OhareFred 1 Quote Link to comment Share on other sites More sharing options...
jose laprovitera Posted March 31, 2023 Report Share Posted March 31, 2023 On 16/6/2020 at 4:56 PM, Kblyk19 said: I have a 2010 Dodge journey that will randomly beep it will be like one beep just random and it’s when my car has been off no windows are down no doors are open the car is locked but when it beeps my wiper blades jump so I know how many times it beeps throughout the night because my wiper blades will move with each beep. the previous owner had a aftermarket alarm system but I don’t use it I use the one that came with the car can someone give me any idea. It’s just one beep. Once in a while. HI, I Have the same problem with my 2009 journey and something wrong had killing the battery!! Quote Link to comment Share on other sites More sharing options...
Yogitech1 Posted April 26, 2023 Report Share Posted April 26, 2023 On 3/31/2023 at 6:41 PM, jose laprovitera said: HI, I Have the same problem with my 2009 journey and something wrong had killing the battery!! I have a similar problem, only my alarm doesn't work, key fob only starts the car, nothing else. The horn randomly blows more than once and even while driving. I installed a separate relay, horn button and after market horns. Tip: Everything runs through the TIPM. Quote Link to comment Share on other sites More sharing options...
