JamieBrooke1105 Posted June 20, 2020 Report Share Posted June 20, 2020 (edited) I have a 2009 Dodge Journey awd r/t. Part of my drive shaft that connects to the cv axel is broken and I am unsure of the name of the part. Does anyone know the part in this video that is broken? I can’t think of what it is called. Thank you! IMG_5472.mov Edited June 20, 2020 by JamieBrooke1105 Quote Link to comment Share on other sites More sharing options...
JamieBrooke1105 Posted June 20, 2020 Author Report Share Posted June 20, 2020 IMG_5472.mov Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 20, 2020 Report Share Posted June 20, 2020 (edited) any part store would be able to answer this as well with a price,,, but for thoes with a answer, what size engine, which side of the journey, fwd where the axle is or at the rear.... info would be helpful Edited June 20, 2020 by 2late4u Armando G 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted June 21, 2020 Report Share Posted June 21, 2020 (edited) your pic doesn’t work. WAG drive shaft flex joint. Is this the pic? https://www.rockauto.com/en/catalog/dodge,2009,journey,3.5l+v6,1442283,drivetrain,drive+shaft+flex+joint,10701 Edited June 21, 2020 by John/Horace jkeaton 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 22, 2020 Report Share Posted June 22, 2020 guess he found out the name of the part since no response in 2 days. OhareFred 1 Quote Link to comment Share on other sites More sharing options...
JamieBrooke1105 Posted June 22, 2020 Author Report Share Posted June 22, 2020 On 6/20/2020 at 5:27 PM, 2late4u said: any part store would be able to answer this as well with a price,,, but for thoes with a answer, what size engine, which side of the journey, fwd where the axle is or at the rear.... info would be helpful It is a 2009 awd R/t with a 3.5L engine v6. It is the brown piece is on the right front passenger side. It is the piece that hooks into the transmission that is broken. Quote Link to comment Share on other sites More sharing options...
JamieBrooke1105 Posted June 22, 2020 Author Report Share Posted June 22, 2020 I have not found out the part yet. I’m a girl also. I have someone coming over to remove it to try and figure out what it’s called. I’m a single mom due to my child’s father passing away at the end of April and I am with a car until I can figure out this part to get my car fixed. Any help would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
JamieBrooke1105 Posted June 22, 2020 Author Report Share Posted June 22, 2020 On 6/20/2020 at 5:27 PM, 2late4u said: any part store would be able to answer this as well with a price,,, but for thoes with a answer, what size engine, which side of the journey, fwd where the axle is or at the rear.... info would be helpful On 6/20/2020 at 5:27 PM, 2late4u said: any part store would be able to answer this as well with a price,,, but for thoes with a answer, what size engine, which side of the journey, fwd where the axle is or at the rear.... info would be helpful Quote Link to comment Share on other sites More sharing options...
JamieBrooke1105 Posted June 22, 2020 Author Report Share Posted June 22, 2020 It’s a 3.5L AWD R/T and it is located in the front next to the transmission on the passenger side of the car Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 22, 2020 Report Share Posted June 22, 2020 dealership would be able to give the correct name and OEM price, and with that you could go aftermarket but be careful of the quality of the aftermarket parts....sometimes the cheap ends up costing more than the OEM route Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 22, 2020 Report Share Posted June 22, 2020 from your video that doesn't look any thing like a cv joint for the front right side unless it is missing a bunch of the part. like rubber boot and the outer metal covering.....google Cardone New® - CV Axle Shaft $47.31 - $55.92 for a picture of what it should look like Quote Link to comment Share on other sites More sharing options...
John/Horace Posted June 22, 2020 Report Share Posted June 22, 2020 (edited) I used android device to view clip. It’s your drive shaft, not a c/v drive axle. Pricy item to buy. May be able to remove shaft and drive in two wheel drive only for now. Mopar unit on roacka is $850 cdn dollars. Choose for Me to Minimize Cost DODGE > 2009 > JOURNEY > 3.5L V6 > Drivetrain > Drive Shaft Price Standard Replacement MOPAR 5157005AF {#05157005AE, 5157005AE} Info HATCHBACK; AWD 1 Day Delay CAD$850.32 More Information for DORMAN 946307 Add to Cart Continue Shopping Edited June 22, 2020 by John/Horace Jaybrew85 and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted June 24, 2020 Report Share Posted June 24, 2020 You will probably have a light on dash without driveshaft in place. But I think car will be driveable. Aftermarket shafts will be a little cheaper than Mopar, although not as durable. Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 24, 2020 Report Share Posted June 24, 2020 there is also the scrap yards as well for used parts Quote Link to comment Share on other sites More sharing options...
John/Horace Posted June 24, 2020 Report Share Posted June 24, 2020 (edited) Yeah another option, the part recyclers. On a low labour installation job like this a very good option. You didn’t need a part that is going to last another 100k if car won’t be on the road that long. https://www.car-part.com/ Edited June 24, 2020 by John/Horace Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted June 25, 2020 Report Share Posted June 25, 2020 driveshaft! Quote Link to comment Share on other sites More sharing options...
jd00d Posted August 5, 2020 Report Share Posted August 5, 2020 From my research it's the CV joint on the driveshaft at the transfer case for the rear wheel drive. Mine isn't that bad, my boot is torn, so it's only a matter of time for mine. I haven't been able to locate just the CV joint. Apparently Mopar thought it wise to only include it with the whole drive shaft. It honestly makes no sense to me when you can buy a rebuilt kit for the same thing on a jk jeep and also on trucks. If anyone actually knows of a comparable part without spending 500 to 1 k for a new driveshaft let me know. Quote Link to comment Share on other sites More sharing options...
Armando G Posted August 8, 2020 Report Share Posted August 8, 2020 Hmmm... let me guess, friend came over, figured it our for her, and she moved on with life. One post wonder... OhareFred and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted August 8, 2020 Report Share Posted August 8, 2020 We knew it was the part, we really didn’t need her conforming that, but repair info would have been useful. Almost guaranteed car is running as a two wheel drive vehicle now. I did that on my 300k Jeep for 6 months before selling it. Here is new shaft for $700 Canadian pesos, can be picked up in Hamilton to avoid $68 for shipping. Oem part. A lot of companies sell only full shaft assembly, common occurrence now. https://www.moparpartscanada.ca/oem-parts/mopar-propeller-shaft-5157005af/?c=Zz11bml2ZXJzYWxzLWFuZC1yZWFyLWF4bGUmcz1kcml2ZS1heGxlcyZpPVRLMDk3MzU1JnI9OCZhPWRvZGdlJm89am91cm5leSZ5PTIwMTQmdD1yLXQmZT0zLTZsLXY2LWZsZXg%3D Quote Link to comment Share on other sites More sharing options...
