Shawn855 Posted July 10, 2020 Report Share Posted July 10, 2020 I'm experiencing popping noise that can also be felt in the steering wheel and gas pedal. Happens when going straight and when turning. Ruled out my strut bearings, stabilizer links, stabilizer bushings. Checked my CV axles and theres no play in them from what I can tell. Sounds like the popping is coming from center of the car when listening inside. Also seems to happen more in really hot weather. Mornings when it isn't as hot as the daytime doesn't do the popping much, but by afternoon in our heat wave, it does it like crazy!!! What do you guys think? 2016 journey sxt 3.6L 80,000 kms Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 10, 2020 Report Share Posted July 10, 2020 usually a clicking noise when turning means a bad cv joint...does it pop when turning in both directions or just one,,,goggle you tube,it has video on how to check them,,,good luck Shawn855 1 Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted July 10, 2020 Author Report Share Posted July 10, 2020 both directions, and also when driving straight and going over bumps. I've been researching it a crap ton the past day lol. Found some people who owned dodge avengers with the exact same noise, and even does it in only warm weather like mine.....seems to point to the steering rack fuck my life. Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 10, 2020 Report Share Posted July 10, 2020 might want to check out eng and trans mounts as well, Summer Solstice and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted July 12, 2020 Report Share Posted July 12, 2020 Unless you are a licensed mechanic with a rack and engine stethoscope you can’t eliminate some stuff you’ve mentioned. Racks usually cause stiff steering and start to leak from seals when they are really shot. My WAG is upper strut mounts, need to lower struts and pivot them by hand to evaluate, although weight of car can change internal play. Normally changed as a unit, although with spring compressor set can be replaced by them selves. https://www.rockauto.com/en/catalog/dodge,2016,journey,3.6l+v6,3353540,suspension,strut+mount,7600 Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted July 12, 2020 Author Report Share Posted July 12, 2020 I thought for sure it was the upper strut mounts as well. I had 1 month old monroe quickstruts in there and thought they went back so I swapped them out for my old pair of struts that I know had no popping noise , and the noise is still there. And yes i lower the vehicle on its own weight before tightening the tower nuts to spec lol Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted July 20, 2020 Author Report Share Posted July 20, 2020 I figured it out. It was the stabilizer bar bushings. I used aftermarket ones that were way too tight and the stabilizer bar wasn't able to flex properly. I swapped to the OEM bushings that have the little fiber mesh inside of them and it stopped the noise. OhareFred, Summer Solstice and 2late4u 2 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted July 21, 2020 Report Share Posted July 21, 2020 (edited) Glad you found it. Front end noises can be very hard to nail down. It seemed way to early for rack issues. Found this decent front end trouble shooting guide...that you now don’t need, cool. https://www.moparmagazine.com/2016/08/their-ride-quality-depends-on-it/ You easy sell the Monroe quick struts. Edited July 21, 2020 by John/Horace Shawn855 1 Quote Link to comment Share on other sites More sharing options...
