MTDodgeGuy Posted July 15, 2020 Report Share Posted July 15, 2020 Hello All, I'm sure this has been talked about before. I have a 2012 Dodge Journey that i need to replace the rear blend door actuator I'm getting a clicking sound from behind the right rear quarter panel. I have a few questions. What is the process of removing the rear interior panel? Do i need to remove the 3rd seat? Next question is do i need to remove any ac lines? I was looking at a post that said i needed to remove t some rear AC lines ? to get to the Actuator. Is that true? Is this a fairly simple job ? Is there somewhere om here that explains the process? Thank you so much Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 16, 2020 Report Share Posted July 16, 2020 dealership would;d be able to give you some advise on it and also parts dept should be able to price it ( get OEM as you want to use a quality part) and show you on a schematic where it is located, also i was watching a you tube on changing the rear struts and they gave pretty good info on removing all the rear plastic coverings, good luck and report back on what happens Quote Link to comment Share on other sites More sharing options...
