Dodge Journey EGT sensor correct oem number
Lado
Hello,
I have an issue with one of the exhaust gas temperature sensors on my 2010 Dodge Journey 2.0 CRD Diesel 140 HP.
Error code is: P0546: EGT Sensor Circuit High Bank 1 Sensor 1.
It needs to be replaced.
Does anyone know what is the correct  OEM part number for this sensor?
I did a search here: https://www.autodoc.co.uk/car-parts/sensor-exhaust-gas-temperature-15077/dodge/journey/journey-2008/28179-2-0-crd
but there are several different reference OEM number, I was wondering which one would be the correct one for Bank 1 Sensor 1?
welcome to the group.hopefully someone outside the U.S can respond to your inquiry as all we have in the u.S. are gasoline engines ,so we might not be able to help you, good luck as we do have a lot of viewers all over the world and when you find out your question please repost what you find...
