Under valve cover melted, engine not running hot
Tony58
engine ran rough then died. Got a code for the fuse box under hood. Changed it and then found can sensor melted. Car never run hot. Then the car started and drove for 3 miles then same exact then happened. Under calve cover was melted and can sensor melted again. Cam shaft has discoloration from heat. Engine never ran hot according to the temp gauge. Can’t figure this one out. Any help would be appreciated.
welcome to the group. please give more info like which engine? what was the code number? what do you mean a can melted?what is Under calve cover was melted and can sensor melted again.. i am sure someone will help out but try to be more clear in what you are saying..good luck
