JSHAW Posted August 14, 2020 Report Share Posted August 14, 2020 Hey peeps! My first post here...and it had to be a problem, I have a dodge journey crossroads, 2015, 24,835 miles (I don't drive alot, hence the low mileage) The AC is not blowing at all in my FRONT vents, none. AC is blowing very cold air to both the rear and 3rd row vents, perfect ice cold air. This same exact scenario happened to me in 2019 during a summer month, but it corrected itself, wasn't overly concerned, it worked, move on. Now a year later it's back again, this time it's not correcting itself. Personally since it's blowing elsewhere in the car I think it's the front actuator doors, or possible burnt out fuse that controls the doors. What's my next steps, locate and check fuses, change fuses....I'm defintely not up for removing the dash to check the doors. Any advice is appreciated Quote Link to comment Share on other sites More sharing options...
Armando G Posted August 16, 2020 Report Share Posted August 16, 2020 Welcome, and yes those are the steps. I don't believe you have to remove the entire dash to check them. Plenty of videos and advise out there, mostly on this site. OhareFred and jkeaton 1 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted August 16, 2020 Report Share Posted August 16, 2020 And Thank You for your service! ?? Quote Link to comment Share on other sites More sharing options...
JSHAW Posted September 20, 2020 Author Report Share Posted September 20, 2020 over 180 views, not 1 person replied with the fix, which was needing a new front blower motor. dealer fixed for nice chunk of change. i have had nice icy cold air for several weeks Quote Link to comment Share on other sites More sharing options...
Whatdidido2015 Posted March 19, 2021 Report Share Posted March 19, 2021 Having exact same problem So it is the front blower motor that's out? It started by only blowing hot in the front now nothing at all just noise Someone help lol just moved to FL Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 19, 2021 Report Share Posted March 19, 2021 if you are not getting any air blowing out then probally the blower or the blower motor resister or a fuse , hard to tell over the internet, do you have dual air or just the one system? Quote Link to comment Share on other sites More sharing options...
Whatdidido2015 Posted March 19, 2021 Report Share Posted March 19, 2021 On 3/19/2021 at 1:07 AM, 2late4u said: if you are not getting any air blowing out then probally the blower or the blower motor resister or a fuse , hard to tell over the internet, do you have dual air or just the one system? Expand I'm not sure what you mean by dual air lol it works as it should in the middle row and 3rd but doesn't blow anything up front Quote Link to comment Share on other sites More sharing options...
OhareFred Posted March 19, 2021 Report Share Posted March 19, 2021 As 2late said, blower motor or blower motor fuse. Separate motors for front & rear with the 3 zone system 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Whatdidido2015 Posted March 23, 2021 Report Share Posted March 23, 2021 I can hear the ac blowing hard just doesn't come out of the front. Would this more the likely be the blend door? Not thinking its the blower motor because its blowing just doesn't come out Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 23, 2021 Report Share Posted March 23, 2021 On 3/23/2021 at 4:04 PM, Whatdidido2015 said: I can hear the ac blowing hard just doesn't come out of the front. Would this more the likely be the blend door? Not thinking its the blower motor because its blowing just doesn't come out Expand I had a similar situation with one of my Chys. minivans that I bought well used... Turned out a mouse had built a large nest in the fresh air pick up in the cowling beneath the wiper assembly. The van could not draw in fresh air for the fan to move it thru the vents. Worked OK on recirc. mode. I've not "dived into" such with out DJ...yet to be able to say about HOW to go about checking/clearing that possibility. Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 23, 2021 Report Share Posted March 23, 2021 On 3/23/2021 at 4:04 PM, Whatdidido2015 said: I can hear the ac blowing hard just doesn't come out of the front. Would this more the likely be the blend door? Not thinking its the blower motor because its blowing just doesn't come out Expand i would say yes a blend door if you hear it running but no air coming out Quote Link to comment Share on other sites More sharing options...
Whatdidido2015 Posted March 24, 2021 Report Share Posted March 24, 2021 How do you go about knowing what blend door to order or is bad I've read there are multiple different ones Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 24, 2021 Report Share Posted March 24, 2021 start watching some you tube videos on blend doors Quote Link to comment Share on other sites More sharing options...
hollyyyberry Posted July 2, 2024 Report Share Posted July 2, 2024 On 3/19/2021 at 1:07 AM, 2late4u said: if you are not getting any air blowing out then probally the blower or the blower motor resister or a fuse , hard to tell over the internet, do you have dual air or just the one system? Expand Quote Link to comment Share on other sites More sharing options...
