Go Reds 433 Posted September 22, 2020 Report Share Posted September 22, 2020 I have a 2016 Journey and all of a sudden the a/c will come on by itself. I only have 13,353 miles on it...yeah I don't drive much. Any one else having the same issue and if so what was the solution. I contacted Dodge and they said they were unaware of this problem. Thank you. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted September 22, 2020 Report Share Posted September 22, 2020 What type system is in your Journey? Is it the auto temp or dual zone MANUAL system? Quote Link to comment Share on other sites More sharing options...
Go Reds 433 Posted September 22, 2020 Author Report Share Posted September 22, 2020 I have the auto temp system, and the setting is off of auto mode Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted September 22, 2020 Report Share Posted September 22, 2020 Seems there are a number of threads started on this issue in this heading page. From what I can gather, it seems to be in the touchscreen or module software. I don't have any troubles (yet) like this as ours is the manual system. I'd suggest spending some time going thru established threads and see if any have "fix" info.....Good Luck! Quote Link to comment Share on other sites More sharing options...
Go Reds 433 Posted September 22, 2020 Author Report Share Posted September 22, 2020 1 minute ago, 5rebel9 said: Seems there are a number of threads started on this issue in this heading page. From what I can gather, it seems to be in the touchscreen or module software. I don't have any troubles (yet) like this as ours is the manual system. I'd suggest spending some time going thru established threads and see if any have "fix" info.....Good Luck! I’ve seen many post but no real solutions. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 23, 2020 Report Share Posted September 23, 2020 (edited) The AC will come on automatically based on humidity levels in the cabin. Even if turned off in the manual mode, the AC system will remain active to prevent fogging. This is normal and explained in your owners manual. Edited September 23, 2020 by jkeaton JhamB and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
Cpt Stitchpool Posted September 27, 2024 Report Share Posted September 27, 2024 On 9/23/2020 at 8:31 AM, jkeaton said: The AC will come on automatically based on humidity levels in the cabin. Even if turned off in the manual mode, the AC system will remain active to prevent fogging. This is normal and explained in your owners manual. Can this be disabled because I dont like my system constantly running in my 2018 DJ, I can turn it off repeatedly and it just keeps turning itself back on Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 27, 2024 Report Share Posted September 27, 2024 9 minutes ago, Cpt Stitchpool said: Can this be disabled because I dont like my system constantly running in my 2018 DJ, I can turn it off repeatedly and it just keeps turning itself back on Yes. You can install a switch to cut power to the compressor when you don’t need it. Quote Link to comment Share on other sites More sharing options...
Dean H Posted September 27, 2024 Report Share Posted September 27, 2024 On my 2016 DJ. On the touch screen go to rear climate controls. Push rear controls off. Push rear controls locked out. or Pull the fuse for the rear HVAC controls. Interior fuse panel. larryl 1 Quote Link to comment Share on other sites More sharing options...
Dean H Posted September 27, 2024 Report Share Posted September 27, 2024 I have the manual HVAC system. Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 28, 2024 Report Share Posted September 28, 2024 my first 2011 journey had the dual system and yes not having the rear set right can make it turn on and off, my 2014 has just the manual system and have never had any problems.. Quote Link to comment Share on other sites More sharing options...
