YellowDuck Posted September 24, 2020 Report Share Posted September 24, 2020 Could someone please give me the torque specs for the front caliper bolts, and the front caliper slider pin bolts? I had a caliper pin bolt drop out after the car was serviced. I'm lucky the pads didn't fall out! I will have the new pins and bolts in hand today, just need to torque specs. 2014 Journey RT. Quote Link to comment Share on other sites More sharing options...
larryl Posted September 24, 2020 Report Share Posted September 24, 2020 Any FCA dealer should be able to give you the correct specs Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 24, 2020 Report Share Posted September 24, 2020 have done almost a hundred brake jobs for my daughters mail van and jeeps and have never used a torque wrench on thoes bolts and never had a problem just get them tight and then a bit more, if one came out then he never even got it tight to begin with probably had it finger tight Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
Carter3Journey Posted October 15, 2020 Report Share Posted October 15, 2020 Hope this helps Repair content for 2014 Dodge Journey(1).PDF Quote Link to comment Share on other sites More sharing options...
Carter3Journey Posted October 15, 2020 Report Share Posted October 15, 2020 Specs for front brakes are in pdf Quote Link to comment Share on other sites More sharing options...
