Borjawil Posted October 13, 2020 Report Share Posted October 13, 2020 I've searched but haven't found much info. I've seen wiring harnesses that connect inside the tail lights and such, as well as issues other have had. 1) if I have a connector under the vehicle,.where would it be and how much? Saw a post of '16 that had one. 2) seen some posts on needing to reflash the computer to use trailer lights, any info on this for my vehicle? 3) any issues with using led brake lights and/or trailer lights? Quote Link to comment Share on other sites More sharing options...
David3921 Posted May 13, 2021 Report Share Posted May 13, 2021 I installed the Curt hitch and harness with no problems on my 2010. The harness is installed inside the tail lights. My trailer has led lights and there are no issues. What I did have issue with is the right exhaust would rub sometimes on the hitch. The clearances are pretty tight. I ended up installing new hangers that allowed the exhausts to hang lower. Below is the harness and hitch I installed; https://smile.amazon.com/dp/B003ZS37K4/ref=au_as_r?_encoding=UTF8&Make=Dodge|40&Model=Journey|6800&Year=2010|2010&ie=UTF8&vehicleId=10&vehicleType=automotive https://smile.amazon.com/dp/B00QMF1HCW/ref=au_as_r?_encoding=UTF8&Make=Dodge|40&Model=Journey|6800&Year=2010|2010&ie=UTF8&vehicleId=10&vehicleType=automotive Hangers; https://smile.amazon.com/gp/product/B07XQ93KMP/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 Quote Link to comment Share on other sites More sharing options...
johanbrandon Posted January 8, 2024 Report Share Posted January 8, 2024 The wiring harness connector for tail lights is typically located near the rear bumper, close to the tail light assembly. Look underneath the vehicle, near the rear axle or bumper, for a connection point. If there's a connector, it might be secured to the frame or body. Prices for replacement wiring harnesses vary based on the vehicle make and model, ranging from $50 to $200 or more. Online automotive parts retailers or local auto parts stores can provide specific prices, and you may find better deals by comparing options from different sources. Quote Link to comment Share on other sites More sharing options...
