Oil leak - intercooler/oil cooler?
Borjawil
09 sxt 3.5 140k swapped engine with 120ish
Trying to figure out a misfire/flickering light issue, and when I was under the car noticed a leak on the driver side front near the radiator drain petcock, a few inches or so up. There are two metal lines about 3/8" diameter. Look like they might go into a radiator type cooler. I can pull on the lines and make them move forward and back (relative to the vehicle). Not sure if they're missing a mount/bracket, are actually sliding in and out of where they go, or what. Tight spot to see.
Couldn't really smell the fluid, but pretty sure it was oil, possibly power steering fluid. I'll post pics when Im able. Any direction right now would help.
