Valve clearance, 2013 2.4L Dodge Journey
Rebeca Davila
Posting again 'cause  we really need help!  We need the valve clearance specs for a 2013 2.4L Dodge Journey but I cannot find it in the manual. I found a clearance spec for a 2009 2.4L - Intake: 0.006-0.009 in. / Exhaust 0.010-0.012 in. Does anybody know if the 2013 2.4L valve clearance is the same? Thanks!
Sorry, but without going "online" searching for you I don't have those type specs handy. But from experience any model(200,Avenger,etc) that has the 2.4 in 2013 would be the SAME for motor specs, you don't need to look specifically for Journey.
Sorry at this instant that I can't offer more direct response.
EDIT: Found on Chrysler 200 forum of referenced clearances being the SAME for a 2012 model. BUT found lots of conflicting info as to them being flat tappet/bucket lifters or hydraulic (and therefore not needing such specs.) GOOD LUCK!
Hi!  We did an online search and found specs for a 2009 2.4L.  I was just trying to confirm if the clearance specs for the 2009 2.4L were the same as for the 2013 2.4L.  Sometimes the specs vary depending on the year.
Thanks!
