Ac drain line location
Brando
  • 3 years later...
I have a 2014 dodge journey crossroad and I have water on the passenger side floor and in the storage cantainer behind the passenger side. I was told that it was a a/c drain line plugged and was trying to figure out where it would be located, I’m hoping that someone could help me locate it
Expand
drain is on the left side under the steering wheel ,if you have water on the passenger side probally have a leak in the firewall seams or door sill leaks,if you have a sunroof that might also be a possible cause
