Shawn855 Posted November 3, 2020 Report Share Posted November 3, 2020 Hey everyone, I obtained the service manual for the dodge journey and now have access to the following torque specs so feel free to post in here if you need them: -Body -Brakes front + back -Cooling system -Engine system -Exhaust system -Fluids chart -Front axle shaft -Front engine mounts -Front suspension system -Rear axle shaft -Rear suspension system -Restraints system -Steering column -Steering system OhareFred, Summer Solstice and 2late4u 1 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 5, 2020 Report Share Posted November 5, 2020 Pinned topic. Thanks for doing this. Shawn855 and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted November 5, 2020 Author Report Share Posted November 5, 2020 Front suspension: DESCRIPTION N·m Ft. Lbs. In. Lbs. COMMENT Brake Shield 10 7 89 Crossmember Mounting Bolts 135 100 — Crossmember Reinforcement Bracket Mounting Screws 50 37 — Hub And Bearing Mounting Bolts 48 35 — Hub Nut 160 118 — Lower Ball Joint Stud Nut 95 70 — Lower Control Arm Front Pivot Bolt 175 129 — Lower Control Arm Rear Pivot Bolt Nut 145 107 — Stabilizer Bar Cushion Retainer Screws 60 44 — Stabilizer Bar Link Nuts 48 35 — Strut Clevis-to-Knuckle Nuts 140 103 — Strut Rod Nut 60 44 — Strut-to-Tower Nuts 55 41 — Tie Rod Adjuster Jam Nut 75 55 — Tie Rod End Knuckle Nut 85 63 — Wheel Mounting (Lug) Nuts 135 100 Rear Suspension: DESCRIPTION N·m Ft. Lbs. In. Lbs. COMMENT Brake Tube Bracket Knuckle Mounting Screw 21 15 — Brake Flex Hose Trailing Link Mounting Screw 20 15 — Hub And Bearing Mounting Bolts 60 44 — Hub Nut 245 181 — Do not reuse these fasteners. If removed, a new fastener must be installed and tightened to specifications. Lower Control Arm Knuckle Mounting Bolt Nut 105 77 — Lower Control Arm Crossmember Mounting Bolt Nut 105 77 — Lower Control Arm Crossmember Bracket to Body 61 45 — Shock Assembly Lower Mounting Bolt Nut 100 74 — Shock Assembly Upper Mounting Nuts 45 33 — Shock Rod Nut 30 22 — Stabilizer Bar Retainer Screws 25 18 — Stabilizer Link Mounting Nuts 100 74 — Toe Link Knuckle Mounting Bolt Nut 105 77 — Toe Link Cam Bolt Nut 95 70 — Trailing Link Body Mounting Bolts 110 81 — Trailing Link Knuckle Mounting Bolts 80 59 — Upper Control Arm Knuckle Mounting Bolt Nut 105 77 — Upper Control Arm Crossmember Mounting Bolt Nut 105 77 — 2late4u, Summer Solstice and agm2112 3 Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted November 5, 2020 Author Report Share Posted November 5, 2020 Glad to help. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
joemel Posted December 24, 2020 Report Share Posted December 24, 2020 Would these torque values apply to all model year Journey's? I'm looking for 2010 FWD 2.4L specs. Thanks. Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted December 24, 2020 Author Report Share Posted December 24, 2020 No. The reason why I obtained the manual specifically for the 2016, is because I noticed the torque specs varied from year to year. Not by a lot, but still. Specifically the brakes if I recall correctly. They increased the torque specs for the brakes in later years of the journey. You can compare for yourself, by going to cardiagn.com, where the 2015 journey torque specs are located and compare them with my 2016 specs. Quote Link to comment Share on other sites More sharing options...
joemel Posted December 24, 2020 Report Share Posted December 24, 2020 Shawn, thank you for the quick reply. Chilton / Haynes / Helm do not publish or offer on line manuals for the 2010 model. The dealership parts dept. state they don't have access to torque specs. Any ideas where I can find torque values for a 2010? Thanks . Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 25, 2020 Report Share Posted December 25, 2020 Get a Mitchel on line login for a month, has all vehicle specs. Lots of independent shops use them. Quote Link to comment Share on other sites More sharing options...
joemel Posted December 27, 2020 Report Share Posted December 27, 2020 HI John / Horace, thank you as well for the idea of Mitchel. I will definitely check them out. Quote Link to comment Share on other sites More sharing options...
Tedybear315 Posted July 6, 2021 Report Share Posted July 6, 2021 Going to throw this one out. Any ideas on the torque for a ball joint nut for a 2010 dodge journey? Just replaced the bad one (pretty badly rusted out internally). My 1/2 torque wrench died and I'm pretty sure it's probably over torqued. I prefer something with a castle nut, but all this came with was a nyloc. Just need that one. I've seen everything from 70ftlbs up to 130ftlbs... Thanks! S- Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted July 7, 2021 Author Report Share Posted July 7, 2021 13 hours ago, Tedybear315 said: Going to throw this one out. Any ideas on the torque for a ball joint nut for a 2010 dodge journey? Just replaced the bad one (pretty badly rusted out internally). My 1/2 torque wrench died and I'm pretty sure it's probably over torqued. I prefer something with a castle nut, but all this came with was a nyloc. Just need that one. I've seen everything from 70ftlbs up to 130ftlbs... Thanks! S- 2010 Dodge journey lower balljoint nut torque spec is 70 ft-lbs. confirmed. John/Horace 1 Quote Link to comment Share on other sites More sharing options...
Tedybear315 Posted July 9, 2021 Report Share Posted July 9, 2021 On 7/7/2021 at 8:37 AM, Shawn855 said: 2010 Dodge journey lower balljoint nut torque spec is 70 ft-lbs. confirmed. Cool!! Thanks!! We just got all the brake parts in to get the front brakes done. Thankfully brake part torque usually doesn't vary greatly. However I'll have to pop for a new torque wrench! I think it's currently probably torqued down to well over 95lbs.. The stupid wrench decided it didn't want to 'click' any longer. Looks like I'll be backing the nut off and re-torqueing it where it belongs. (Sidebar note: For some daft reason I never get notified of responses...I just happened to look here and it finally flagged it on the page itself. I'll need to check my email settings) Thanks Again!! S- Quote Link to comment Share on other sites More sharing options...
Guillaume Posted September 4, 2021 Report Share Posted September 4, 2021 Do you have the torque spec for the rear brakes? Specifically the caliper bolt and the caliper mounting bracket bolt. Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted September 4, 2021 Author Report Share Posted September 4, 2021 5 minutes ago, Guillaume said: Do you have the torque spec for the rear brakes? Specifically the caliper bolt and the caliper mounting bracket bolt. Rear brake mounting bolts: 80ft-lbs Caliper bolts: 26ft-lbs Quote Link to comment Share on other sites More sharing options...
Tedybear315 Posted September 4, 2021 Report Share Posted September 4, 2021 5 minutes ago, Shawn855 said: Rear brake mounting bolts: 80ft-lbs Caliper bolts: 26ft-lbs Thanks for that!! I'll be doing our rear brakes in a couple of days and was going to ask this! S- Quote Link to comment Share on other sites More sharing options...
Guillaume Posted September 4, 2021 Report Share Posted September 4, 2021 You’re fast! I just posted that. Thanks a lot. Quote Link to comment Share on other sites More sharing options...
moe mclay Posted March 18, 2023 Report Share Posted March 18, 2023 need 2010 sxt journey specs for engine Quote Link to comment Share on other sites More sharing options...
Ali Posted August 22, 2023 Report Share Posted August 22, 2023 (edited) I neeed torque specs for inner and outer tire rods for a dodge Journey 2012 sxt Can anyone help please? Edited August 22, 2023 by Ali Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 22, 2023 Report Share Posted August 22, 2023 2 hours ago, Ali said: I neeed torque specs for inner and outer tire rods for a dodge Journey 2012 sxt Can anyone help please? just type in torque specs for 2012 inner and outer tie rods on google.......................... 2012 Dodge Journey 2.4L Front End Torque Specs dodge-specs.com https://dodge-specs.com › cars › 2012 › journey2.4 This inner tie rod screws into the power steering rack and can be torqued down to 55 ft-lbs. Be sure to inspect and measure your old tie rods so that the new ... People also ask How much torque should an inner tie rod have? The inner part of the tie rod (differential-to-drive axle flange nut) is torqued between 40 to 47 foot pounds. The outer part of the tie rod (tie rod end nut) is torqued between 31 to 42 foot pounds.Feb 13, 2017 Quote Link to comment Share on other sites More sharing options...
Mopman Posted January 26 Report Share Posted January 26 I need torque settings for 2016 crossroad v6 lower intake manifold, would anybody have that? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted January 29 Report Share Posted January 29 https://drive.google.com/file/d/1zX8rfowBmx1KZpx7zNHQENgcxjFnDjuw/view?usp=sharing Somebody posted this, worked last week. Tricky to navigate if you don't have right device, 5,400 pages of info. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted January 30 Report Share Posted January 30 Better link with index. http://www.dodgia.com/ Quote Link to comment Share on other sites More sharing options...
