Nitish Posted November 3, 2020 Report Share Posted November 3, 2020 Hi all I bought dodge journey2011 R/T and drive 400 km back to home and it start battery icon on EViC shows "Battery Saver Mode" and drive next day and it first stop audio and then shows lights on screen and stop the car and then i try to start with jumper cable it starts but not run. I tow the car changed battery and cables but it showed same lights and not starting car and show the massage Ignition or other accessory is On. I don't know what happened I just bought and it happened I am so anxious. Please help me and tell what is the actual issue. Quote Link to comment Share on other sites More sharing options...
larryl Posted November 3, 2020 Report Share Posted November 3, 2020 I would start with getting the battery and or alternator tested for issues Quote Link to comment Share on other sites More sharing options...
Nitish Posted November 3, 2020 Author Report Share Posted November 3, 2020 (edited) I changed the battery and cables but same issues. What should I do check alternator or any other thing? Edited November 3, 2020 by Nitish Quote Link to comment Share on other sites More sharing options...
OhareFred Posted November 3, 2020 Report Share Posted November 3, 2020 (edited) AutoZone or other auto parts stores usually can test your battery and alternator for no charge. If the battery was bad and you replaced it, and you still have a charging/starting issue, an alternator test would be the next step. Also, if you just bought it, if it was from a dealer I’d be calling them to deal with it. Edited November 3, 2020 by OhareFred Quote Link to comment Share on other sites More sharing options...
Nitish Posted November 3, 2020 Author Report Share Posted November 3, 2020 I bought from old lady but I mechanic checked the alternator it is fine. May be other sensor or computer pcm. What you think? Quote Link to comment Share on other sites More sharing options...
2late4u Posted November 4, 2020 Report Share Posted November 4, 2020 you are wanting to throw good money at it without knowing whats wrong,. have a good mechanic check it out or go to the dealership for a diagnostic,,,are you sure the battery is good ,,,have it load checked as well jkeaton and Summer Solstice 2 Quote Link to comment Share on other sites More sharing options...
Nitish Posted November 4, 2020 Author Report Share Posted November 4, 2020 battery is new Quote Link to comment Share on other sites More sharing options...
NavalLacrosse Posted November 4, 2020 Report Share Posted November 4, 2020 Have a mechanic check the Alternator. Mine experienced similar symptoms as you described. (If) The alternator has failed, or is no longer providing the power to charge the car. Without the alternator, the car is desperately trying to maintain basic operation (driving) by killing non-essential processes. First on mine was the radio, then the HVAC, then the ABS, Speed Sensors, and eventually the engine sputtered to death after 40 minutes. If you delay, the new battery may also be permanently damaged, needing a possible replacement again. After changing the alternator on my car, the issues went away. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted November 4, 2020 Report Share Posted November 4, 2020 (edited) What were the numbers on the battery and alternator tests? A proper newer testing device will give you a printout with the numbers. I agree, you will kill the battery if you are trying to drive it around with a bad alternator. Put the battery on a slow,smart charger until it reads full, then go get the alternator tested again. Tell use what the results are. Good luck!! Edited November 4, 2020 by OhareFred jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Nitish Posted November 5, 2020 Author Report Share Posted November 5, 2020 I will go to the mechanic tomorrow and find the reading on that Mechanic also told me about alternator issues. It is alternator not more serious then that. I will posted. Thanks OhareFred 1 Quote Link to comment Share on other sites More sharing options...
Nitish Posted November 9, 2020 Author Report Share Posted November 9, 2020 Hi Guys I got solution alternator was bad changed it. Now car runs gud. Thanks to all of you help me alot. OhareFred and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted November 9, 2020 Report Share Posted November 9, 2020 4 hours ago, Nitish said: Hi Guys I got solution alternator was bad changed it. Now car runs gud. Thanks to all of you help me alot. thanks for the next poster to ask the same question Quote Link to comment Share on other sites More sharing options...
