New led fog lights and emblem
Seb
  On 11/16/2020 at 1:47 AM, John/Horace said:
Got a link?
Expand
It says it doesn't fit the Journey but as you can see it does perfectly. They have lots of accessories for the Journey on Aliexpress. It took almost a month to get because of covid-19 pandemic. But it's worth the wait.
Cool info. It says fits 2009-2013 journey on alie express site. I wonder about that range, odd.
Amazon ca versus com pricing often varies quite a bit. Especially on shipping.
So fog light switches from white to yellow but doesn’t flash when direction signal is used on Journey? But only if fogs turned on.
Seb your 2014 is already led from factory, no diodes had to be added for this set up?
You bought the led eye brow lights that they show on Ali G express site, as well? You have the auto head light option?
Expand
Journey's only have back break lights that are factory led. All other lights are Halogen. The fog lights have 3 modes.#1 DRL: Halo stays on if fog lights are off. #2 : Fog lights =Halo and center  is lite white. #3 Turn signals/ Hazard lights  =  amber  flashing light. Halo is amber when flashing. If fog lights are off it doesn't go back to white Halo until signals are off. The lights will fit all Journey's. The fog lights diameter and shape hasn't changed on the Journey's ever. Only the body has changed a little bit from 2009 to 2019
  On 11/18/2020 at 4:07 PM, KnightRoller said:
Are the fogs plug-n-play? Or do they require additional wiring? They look great!
The headlights look awesome as well!
Expand
The headlights are plug and play. Fog lights are not. But they come with the required connections. You just have to take OEM plug off. Than wire the other plug and tape it. It's not complicated. In the picture i loaded is the plug you need to cut.
