Catastrophic failure - 2013 SE, 2.4L?
fishinfart
Wife was driving last night alone when she heard a strange noise from under the hood, within seconds it started skipping and by the time she found a safe place to pull over, the engine died as she came to a stop. The plastic tee that has the two main coolant hoses and the radiator cap attached broke and one of the radiator hoses completely separated from it.  Of course that caused an immediate overheating that done major damage within seconds. She said it never read hot on the gauge and had no warning lights or bells. I attached a pic of the broken tee.
I had it towed home this morning - it obviously had low compression when I tried to start, so I checked it - 15, 0, 0, and 30 psi. Engine is toast. :gaah:
I included pics of the spark plug boots where two of them had part of the plastic sleeve they fit in melted to them and all were cracked. That sucker got HOT. No evidence that the radiator cap ever released any coolant into the reservoir, as it is at the same level as it usually is and reservoir cap is intact.
Appears as though the plastic tee just gave up the ghost under normal operating conditions and now I have a destroyed engine. I have no doubt the head is toast, but do you guys think there is a chance that the block and lower end may be salvageable?
2013 Journey SE, only 99k miles, well maintained, never had any real issues except heater hose tee cracked and I replaced both with brass tees several months ago..
5fb975a7cac02_waterneck.thumb.jpg.202e744db51d940be1401a863ef51b12.jpg5fb975af89965_plugboots.thumb.jpg.3e033cdc2f00d544c05f784160fc1944.jpg
Edited by fishinfart
A chance, but slim. I had the same thing happen to a previous car and after a new head, a bit of reboring part of the block (I think that's what it was that they did), and replacing a few other parts that over heated, the car was good. It was that @ $3500 or a little over $6000 for a full engine replace... used at that.
Sorry that happened to you.
  • 2 weeks later...
I almost killed my 3.6 with an oil cooler major leak. Hopefully I had an overheating chime and light. No damages.
PS: Who created this plastic parts holding high pressure/temperature fluids ?
Edited by agm2112
well we can blame the car manufacturer who have their engineers looking for the lightest and cheapest way to build a car, because as most of us always look to buy the cheapest and best looking car as well. DONT get me wrong i am not condoning this use of plastic as we all dont want it to happen to us,to be honest as we look at new models and whoo and wow at all the fancy new electronics and we dont think hmm what is going to go wrong with all this stuff in a couple of yrs like the journey with its common electrical gremlins and navigation problems and such, and lets not forget the battery location.
This aluminum/plastic style oil cooler is being used on a whole range of cars now. Plastic is even used for engine oil pans.
If properly designed it should last a long time. Milled aluminum would later forever.
A lot of other car parts are better designed today than 20 years ago, like spark plugs, braking systems, even radiators.
That sucks! Plastic gets brittle with age which you would think a hose T would last a bit longer than that. I’d check for a decent used engine. They’re pretty common since they were also used in the Avenger. If you have a good local mechanic who knows what they’re doing then a rebuild might be possible but there’s no telling what has happened on the inside.
  • 3 years later...
On 11/21/2020 at 5:14 PM, larryl said:
I have one now it'sy second one don't know why I bought a better looking crossroad I'm pissed because you whole engine is plastic. All the things melt from the coolant hoses filler neck thermostat housing all melted I'm really tired of changing everything in this car
Dodge knew what they was doing
