Rustyleader Posted November 29, 2020 Report Share Posted November 29, 2020 I changed my dead battery and in the process, the cables touched and created a short circuit. Now the windshield wipers are running by themselves, the brake booster pump is running on its own, lights are on, checked all fuses, and car won’t start. Is there anybody out there who has had the same or similar problem? Is there a way to reset the electrical system? Please help anyone!! Quote Link to comment Share on other sites More sharing options...
2late4u Posted November 29, 2020 Report Share Posted November 29, 2020 dont understand about the cables touching each other as they couldn't have been attached to the battery to short out to each other? Armando G and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted November 30, 2020 Report Share Posted November 30, 2020 (edited) They were in the process of being attatched to the new battery. So not attached any more. Polarity reversal in play as well. Could have shorted out body ground control module or maybe the negative terminal current sensor right at battery post connection. I’m not sure. If you get it running and no charging, there is a 150 amp alternator fuse in main panel usually. Check all fuses first, even having blown fuses can do weird stuff. The push button start fuse is in the passenger side front kick panel fuse box, it’s F121. Red 10 amp I think. Free advice worth everything you pay for it. DODGE > 2013 > JOURNEY > 2.4L L4 > Electrical > Battery Current Sensor Price BOSCH 0199200180 {#4692269AI} Electronic Battery Sensor For vehicles with electronic battery management system Out of Stock Edited November 30, 2020 by John/Horace Quote Link to comment Share on other sites More sharing options...
2late4u Posted November 30, 2020 Report Share Posted November 30, 2020 LOL didnt really want to ask if he installed it and reversed the polarity but was wanting to say that, that is about all i can think that would have caused any damage to the journey...also i have seen a car jump start okay with a battery temperature sensor that is bad but then as soon as they put it in gear it would stop OhareFred, John/Horace and Summer Solstice 3 Quote Link to comment Share on other sites More sharing options...
