agm2112 Posted December 2, 2020 Report Share Posted December 2, 2020 This is really weird. I had a problem with my ESP module (the one with the lateral acceleration sensors), and after replacing it, everytime a start my Journey, that stupid message with the "accept" button that normally goes away after a few seconds, stays there. I have to click on it 50 times a day. I don't know if is just a coincidence, or if had to do with the "lateral acceleration module" change, but the fact is that this message won't automatically go away, and I have to click on that button EVERYTIME I start my car. Any help please ! Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 2, 2020 Report Share Posted December 2, 2020 have no idea what button you are talking about ("lateral acceleration module") Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 2, 2020 Report Share Posted December 2, 2020 What are you accepting by pushing the button? Quote Link to comment Share on other sites More sharing options...
NavalLacrosse Posted December 2, 2020 Report Share Posted December 2, 2020 (edited) the accept button signs away your soul. It's the button on the Radio. it shows up every time the radio stack resets. This is probably me suggesting tylenol for a bullet wound... But this sounds like an electrical bug causing the radio head to reset from time to time: try the simple computer full reset procees: it costs nothing, and might fix/diagnose the issue. Unplug the car battery for 33-45 minutes and let the car do a hard reset. plug it back in. If this fixes the problem, you're golden!. If the issue comes back after a few days, I have a diagnosis (or at least another test to try) I'm guessing you've already had your battery and alternator checked? A symptom of a (not failed yet, but) less-than-100% car battery is unexpected and hilariously unrelated electrical gremlins- including issues with the stability computer, ABS controller errors, thermometer readings (-40), bluetooth connectivity, key-fob detection, keyless entry error, and radio glitches (mine would not let me change the volume knob down, but only up- radio station would not change.) After replacing my battery with a new one, the radio issues disappeared. to diagnose this issue, 'jump' your Dodge Journey with either a fully charged jump pack, or another running car (meaning your dodge is using any of the power it needs from the other car, supplementing your own battery.) If the issue goes away while being connected by the jumper cables it's pretty clear the battery is your issue, or at least it's an avenue to explore. Weird right? Anyway. good luck. Edited December 2, 2020 by NavalLacrosse jkeaton and agm2112 1 1 Quote Link to comment Share on other sites More sharing options...
agm2112 Posted December 2, 2020 Author Report Share Posted December 2, 2020 S**t, I'm a Portuguese speaker ... lol https://www.wranglerforum.com/threads/how-to-get-rid-of-uconnect-accept-screen.2329501/ jkeaton 1 Quote Link to comment Share on other sites More sharing options...
NavalLacrosse Posted December 3, 2020 Report Share Posted December 3, 2020 Bom Dia from the states- I'll be flying down to Curitiba-PR for Christmas. (unrelated!) So, to clarify: (in the correct operating conditions) : The 'Accept' button will disappear automatically after 3-5 seconds. In your Freemont: is the 'Accept' button not disappearing automatically? or is the radio rebooting by itself multiple times on the same drive? jkeaton 1 Quote Link to comment Share on other sites More sharing options...
agm2112 Posted December 8, 2020 Author Report Share Posted December 8, 2020 Good Morning ! Yes... this is my problem. The radio is not rebooting. Everything is working as it should. Just this stupid message that is not going away after 5 seconds. Coincidence or not, this started to happen after I replaced the "Lateral Acceleration Module" on my Journey with a used one from a Fiat Freemont, both 4x2 (hard to find here in Brazil, almost all Dodges are 4x4). Worked fine, no more ABS+ESP error lights. Quote Link to comment Share on other sites More sharing options...
Armando G Posted December 8, 2020 Report Share Posted December 8, 2020 I believe it's coincidence. Try resetting the radio with one of the methods on YouTube (not sure which radio you have). If not, call uconnect's help number. They helped me with an issue before. Quote Link to comment Share on other sites More sharing options...
