Beepee Posted December 2, 2020 Report Share Posted December 2, 2020 My 2010 Dodge Journey was blowing cold air on passenger side and after reviewing posts I replaced the blend door actuator it is working properly but the vehicle still blows cold air on passenger side any suggestions? Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 3, 2020 Report Share Posted December 3, 2020 believe there are 3 blend doors drivers ,passenger and one hard to get to in the middle, check out you tube for more info,,,,,good luck Quote Link to comment Share on other sites More sharing options...
Reb78 Posted December 4, 2020 Report Share Posted December 4, 2020 (edited) Probably the heater core. Post a pic of your HVAC control unit. Edited December 4, 2020 by Reb78 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 4, 2020 Report Share Posted December 4, 2020 On 12/4/2020 at 3:40 AM, Reb78 said: Probably the heater core. Post a pic of your HVAC control unit. Expand if it was the heater core it would be cold on both sides and on defrost.........are you getting heat on the drivers side? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted December 5, 2020 Report Share Posted December 5, 2020 (edited) On that age vehicle, members are correct that it's probably the heater core. I had the same concern and flushed the core and got back great pass side heat on my son's '11 DJ. Loss of pass side heat is a common heater core issue with the DJ/Avenger/200 and a number of other FCA/MOPAR models. Edited December 5, 2020 by 5rebel9 Quote Link to comment Share on other sites More sharing options...
Reb78 Posted December 6, 2020 Report Share Posted December 6, 2020 There’s a class action law suit for these early year Journeys for core sand not being removed from the engine block correctly and plugging the coolant system especially heater cores. Quote Link to comment Share on other sites More sharing options...
