dwa315 Posted December 6, 2020 Report Share Posted December 6, 2020 I have a 2018 dodge journey V6. Its throwing a cylinder 6 code. I have replaced a 6 spark plugs, the coil and the the fuel injector on cylinder 6. Its still throwing the same code. Please help! Quote Link to comment Share on other sites More sharing options...
yyz Posted December 6, 2020 Report Share Posted December 6, 2020 You may just want to actually post the code that's coming up. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 6, 2020 Report Share Posted December 6, 2020 (edited) I’m assuming cylinder 6 misfire. Compression on cylinder would be useful info. Leak down and pressure. Lower intake manifold has seals, could be bad on cyclinder 6. They are sold individually and as a set. New coil could be a dud, low probability, but possible. Edited December 6, 2020 by John/Horace Quote Link to comment Share on other sites More sharing options...
Armando G Posted December 6, 2020 Report Share Posted December 6, 2020 With the engine covered under the 5 yr/50k powertrain warranty, have you taken it in to your local dealer? Your car is 3 years old at most so you shouldn't be having these issues. Let them figure it out... and pay for it. jkeaton and larryl 2 Quote Link to comment Share on other sites More sharing options...
dwa315 Posted December 13, 2020 Author Report Share Posted December 13, 2020 (edited) Thank you for the replys. Unfortunately it has 90k miles on it. Its internal. Talked to 3 different mechanics. All 3 said the same thing. Edited December 13, 2020 by dwa315 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 13, 2020 Report Share Posted December 13, 2020 (edited) Did they actually hook up a compress tester and diagnose valve or cam shaft on intake side? Its about an hours labor to do this test. Was the car maintained with oil changes etc, just curious. Tough time for this kind of thing. Edited December 13, 2020 by John/Horace Quote Link to comment Share on other sites More sharing options...
