I bought a 2019 journey which had the basic 4.3 radio, I have purchased a 4.3 s which has satellite out of a 2018. I have run the new satellite antenna cable. Will I have any other issues to make it work? Any help would be great, thanks
Did you also change the antenna?  If not, then that is probably going to be a required - unless somehow they put in a satellite antenna into your vehicle.
The only other thing is that you'll need an unlock code for the radio once it is installed in the vehicle - take note of the serial number of the radio module and mark down the VIN from your vehicle - those two variables go into calculating the code.
Edited by bramfrank
