JACS Posted December 26, 2020 Report Share Posted December 26, 2020 My Dodge Journey 2016 was working good, but suddenly while driving the engine just turned off. Panel and lights continue as normal. It began trying to start again on its own. The only way I could get it to stop cranking and turn it off was to put on parking again and then to N. The check engine turned on. Took it to the repair shop, codes were specific of crank and cam sensor (not sure written correctly). They were replaced. 4 days later, again same story. Check engine on again, now it was like low voltage. recommendation was to replace battery which I did. Next day, while driving, engine again turned off. Now the car cranks but does not starts. Lights, radio, and everything inside powers normally. Scanners connected to the computer get no power from it so no codes. Any suggestions on why could this be happening? Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 26, 2020 Report Share Posted December 26, 2020 2016 but no mention of miles, you might still have some power train warranty left 3 yrs or 60 k..just a thought Quote Link to comment Share on other sites More sharing options...
JACS Posted December 26, 2020 Author Report Share Posted December 26, 2020 50k miles Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 27, 2020 Report Share Posted December 27, 2020 (edited) then you still have warranty if its the engine or drive line,,, call your dealership with your vin # and ask what is covered just so that you will know for sure,,, my daughters jeep just started leaking gear lube out her front axle ( 4 by 4)2016 51600 miles called the dealership and he said yep its covered till 60 k in the shop now Edited December 27, 2020 by 2late4u Quote Link to comment Share on other sites More sharing options...
JACS Posted December 27, 2020 Author Report Share Posted December 27, 2020 Powertrain warranty covers engine and transmission, the thing is that it is some kind of electrical problem which I don’t think is covered under it. I will take it to the dealership for a diagnosis. Thanks for the advice. Quote Link to comment Share on other sites More sharing options...
G-man Posted February 23, 2021 Report Share Posted February 23, 2021 Good afternoon all, Just wondering if you were ever able to get your Journey started ever again? What did you find to be the issues? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 23, 2021 Report Share Posted February 23, 2021 Troll. Quote Link to comment Share on other sites More sharing options...
