danager1989 Posted December 30, 2020 Report Share Posted December 30, 2020 So I changed the thermostat in my journey because it was stuck open (not good in winter). It would get warm and the heater would blow warm, but the engine never got to full operating temp and heater wasn’t reaching its potential either. So now I replaced the thermostat, added new coolant, and the engine/coolant get to temp but the heater blows colder than before. Any ideas? Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 30, 2020 Report Share Posted December 30, 2020 Trapped air? Did you bleed the system properly? It’s a PIA process.... Summer Solstice and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
danager1989 Posted December 30, 2020 Author Report Share Posted December 30, 2020 That makes sense. Went to bleed it and subsequently broke the bleeder valve so part of it is out and part is in the thermostat. This day is going awesomely. 2late4u, Summer Solstice and OhareFred 1 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 31, 2020 Report Share Posted December 31, 2020 that is why mine is in the shop today, really dont like working on some problems, mine is the rear back up camera problem and also that is why i bought the Mopar Max warranty,,,sorry you are having problems but sounds like you have it under control good luck Quote Link to comment Share on other sites More sharing options...
probak118 Posted December 31, 2020 Report Share Posted December 31, 2020 (edited) Ok educate me, air bleeder valve where is that located ? When I changed mine a year ago I simply removed the pressure cap on the reservoir bottle cranked the heat and let it run until it circulated. watched bubbles escaping thru the reservoir bottle. After googling, I answered my own questions thanks something I did not do, must have got lucky. Edited December 31, 2020 by probak118 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 31, 2020 Report Share Posted December 31, 2020 Sorry, mine goes to the dealer for everything except wipers and brakes. Those 2 things I do. I also have Lifetime Maxcare. Smartest move I ever made... 2late4u 1 Quote Link to comment Share on other sites More sharing options...
danager1989 Posted January 2, 2021 Author Report Share Posted January 2, 2021 bleeder screw is on the thermostat housing, top side. Quote Link to comment Share on other sites More sharing options...
danager1989 Posted January 2, 2021 Author Report Share Posted January 2, 2021 Could an engine really rise or fall 10+ degrees in about 60 seconds? That's what happens as I drive. Am I barking up the wrong tree and maybe need to replace the coolant temp sensor? Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 2, 2021 Report Share Posted January 2, 2021 first which engine do you have? Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 2, 2021 Report Share Posted January 2, 2021 possible pluged heater core ? are both heater core hoses hot and cold or what? Quote Link to comment Share on other sites More sharing options...
