ejay Posted January 3, 2021 Report Share Posted January 3, 2021 Hi guys i need help i changed my blend actuator with a doorman 604-209 and only 2 modes work the front and feet vents, do i just need to go to a dealership and get it recalibrated ? thank you in advance. Quote Link to comment Share on other sites More sharing options...
probak118 Posted January 3, 2021 Report Share Posted January 3, 2021 (edited) Thought I saw something on this site about how to re-calibrate actuators....do a search here or google that.if these do not work. Here are copies and pasts from another thread. Posted June 30, 2020 found this on goggle dont know if it really works ..good luck............... Blend Door Actuator Motor Calibration Turn ignition key to the on position and turn on the HVAC system. Move the key to the off position. Open hood (bonnet for the RHD guys) and locate fuse #15 in the fuse box next to the battery. Remove the fuse and wait 1-2 minutes for any capacitive charges in the system to dissipate. Replace the fuse. Turn the ignition key to the on position. You can now watch the motors move as the system goes through the calibration routine. Leave the key on for a couple of minutes to make sure that the calibration routine is completed before turning it off. You will also be able to hear additional activity as all the doors and fan speed are calibrated. You may have to run the cal routine a couple of times to get the system back to full functionality. If the position of the new door is significantly different from the point at failure, the system will successively move toward the new correct position setting. It may take two or three cycles for the system to move to the correct position. Quote Report post Posted June 30, 2020 THank you. I also had seen this when scouring for information but it seemed like it applied to too many vehicles to be real. I guess I'll have to give it a try anyway! Thanks! Report post Posted June 30, 2020 hope it works and maybe some one else will chime in on this,it has been discussed quite a bit on replacing one but cant remember anyone talking about it had to be calibrated Quote Report post Posted June 30, 2020 Following up here. I think this is the easiest way to "calibrate" the new actuator manually: Connect the actuator to the power connector, and just let it hang loosely. Turn on the car. Turn the heat all the way up on the climate control. This will trigger the actuator to go to "hot". Manually figure out how the blend door arm needs to be do deliver hot air (the arm needs to be all the way up and you can use your hand to get it there). Turn the car off. You now know that the climate control, the actuator and the air door are set to "hot". The arm connected to the actuator itself will need some guess and check to make sure that its in the up- most position when you install it and tighten the three screws. Once installed, turn the car back on and slowly turn the heat down to test the placement of the actuator arm. Once turned all the way down to cool, the cool air should be coming from the vents. There's probably a way that the dealership could have done this electronically, but this worked fine for me. I hope it helps someone else. Thank you! Edited January 3, 2021 by probak118 2late4u and Summer Solstice 2 Quote Link to comment Share on other sites More sharing options...
Hankster Posted January 7, 2021 Report Share Posted January 7, 2021 On the journey yo simply move the heat slowly all the way up then all the way down. Its as simple as that. Quote Link to comment Share on other sites More sharing options...
