Bill Adams Posted January 16, 2021 Report Share Posted January 16, 2021 I got transmission problems in my Dodge Journey. It shifts weird. Sometimes down shifts for no reason. transmission was completely rebuilt about a year ago. all I’ve done so far is make the fluid level is good. and check codes. P735 Gear 5 Incorrect Ratio P0732 Gear 2 Incorrect Ratio And P2807 Pressure Control Solenoid "G" I’m thinking pressure control solenoid may be causing the others. Am I on the right track? and thanks in advance. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted January 17, 2021 Report Share Posted January 17, 2021 How long is repair warranty? Complete rebuild was what, torque converter, pump and solenoid pack.? How many miles before rebuild was done, and since rebuild. Input and output speed sensors issues can create sudden shifts. Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 17, 2021 Report Share Posted January 17, 2021 (edited) My dealership ( in Alabama) tells me oem repairs at the dealership come with a 2 yr unlimited mileage on each repair Edited January 17, 2021 by 2late4u Quote Link to comment Share on other sites More sharing options...
Bill Adams Posted January 18, 2021 Author Report Share Posted January 18, 2021 First rebuild, over two years ago. Second was under warrantee. it’s no longer under warrantee. if it was still under warrantee, I wouldn’t be asking for help? And I will never take anything back to that transmission shop, again. In addition to the second rebuild, a few month’s after it wouldn’t start. Starter wouldn’t turn. While pulling the starter, I found a ground cable not connected. A cable they failed to reconnect. Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 18, 2021 Report Share Posted January 18, 2021 sorry if we offended you as we dont know all what has been done or where it has been done, sounds like you need a different repair place this isn't fixable over the internet, yes Dodge dealership cost more but they give a better warranty and also they take better care of the problem, sorry you are finding this out the hard way, i hear jasper transmissions are one of the better repair shops , google them and look for one of their repair shops and they do offer longer warranties as well, good luck larryl, Bill Adams and OhareFred 3 Quote Link to comment Share on other sites More sharing options...
Bill Adams Posted January 18, 2021 Author Report Share Posted January 18, 2021 I wasn’t offended. Was a little confused about where all the warrantee talk came from. I appreciate everyone’s time and advice. Thanks all. Bill Quote Link to comment Share on other sites More sharing options...
OhareFred Posted January 18, 2021 Report Share Posted January 18, 2021 You would not believe how many people ask a million questions about repairs that would be covered under some warranty. When we are guessing, we ask about warranties. larryl 1 Quote Link to comment Share on other sites More sharing options...
agm2112 Posted January 22, 2021 Report Share Posted January 22, 2021 On 1/16/2021 at 7:15 PM, Bill Adams said: P735 Gear 5 Incorrect Ratio P0732 Gear 2 Incorrect Ratio And P2807 Pressure Control Solenoid "G" I’m thinking pressure control solenoid may be causing the others. Am I on the right track? and thanks in advance. Seems the pressure control valve is making gear 2 and 5 slip, but soon you will have a complete slippage mess. MAYBE you can do a fluid change and inspect the filter and magnet for shavings / sludge, and clean (or replace) just the PCV. I don't like to spend money, so a valvebody replace and transmission teardown would be my last resort. Quote Link to comment Share on other sites More sharing options...
Bill Adams Posted January 25, 2021 Author Report Share Posted January 25, 2021 I replaced the Force control solenoid. That cleared the P2807 code. No real change is symptoms. Quote Link to comment Share on other sites More sharing options...
alpadilla73 Posted March 29, 2021 Report Share Posted March 29, 2021 Do you have to drop the transmission to replace the Force control solenoid? I cant find any info on removing the cover that holds the solenoids. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted March 30, 2021 Report Share Posted March 30, 2021 Get a Mitchel login, they have all vehicle data for maint. Quote Link to comment Share on other sites More sharing options...
Tl94yq Posted April 11, 2021 Report Share Posted April 11, 2021 (edited) On 1/17/2021 at 9:19 PM, 2late4u said: sorry if we offended you as we dont know all what has been done or where it has been done, sounds like you need a different repair place this isn't fixable over the internet, yes Dodge dealership cost more but they give a better warranty and also they take better care of the problem, sorry you are finding this out the hard way, i hear jasper transmissions are one of the better repair shops , google them and look for one of their repair shops and they do offer longer warranties as well, good luck Jasper is not a shop... they sell remanufactured engines and transmissions... That being said they have a great warranty 3yrs/100k Not sure who puts 100k on a passenger car in 3 yrs avg is 12k/yr 3 http://qms.jasperengines.com/warranty.as Edited April 11, 2021 by Tl94yq Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 11, 2021 Report Share Posted April 11, 2021 21 minutes ago, Tl94yq said: Jasper is not a shop... they sell remanufactured engines and transmissions... That being said they have a great warranty 3yrs/100k Not sure who puts 100k on a passenger car in 3 yrs avg is 12k/yr 3 http://qms.jasperengines.com/warranty.as didnt try to say they were a shop that makes and installs them, yes it is a manufacture that rebuilds them and also sells them thur their authorized shops, was just giving a different option of going thur the dealership or regular transmission shops, have heard a lot of good things about their products Quote Link to comment Share on other sites More sharing options...
Tl94yq Posted April 11, 2021 Report Share Posted April 11, 2021 (edited) 26 minutes ago, 2late4u said: didnt try to say they were a shop that makes and installs them, yes it is a manufacture that rebuilds them and also sells them thur their authorized shops, was just giving a different option of going thur the dealership or regular transmission shops, have heard a lot of good things about their products I got a rebuilt tranny for my 96 ram 1500 from them.... not one issue since which that year is notorious for slipping problems in different gears.... buddy of mine who is on the east cost ordered one had it delivered to my house for me wasn't too bad on price either considering I got the buddy hookup I paid nothing in markup...they unloaded right from the box truck and since I had the old pulled no core chare was charged we unloaded it from the box put the old one in the box and they waited the 10 min to do so... After 3 different trans specialist went through it said 3 different things fixed with the replacement without any other issues. Edited April 11, 2021 by Tl94yq Quote Link to comment Share on other sites More sharing options...
John/Horace Posted April 11, 2021 Report Share Posted April 11, 2021 All the cvt trans are crate rebuild now. Dealerships just swap out the units with the reman. Specialized tools make it too hard for independents or dealers to take it on. Quote Link to comment Share on other sites More sharing options...
bramfrank Posted April 18, 2021 Report Share Posted April 18, 2021 On 4/11/2021 at 12:48 AM, John/Horace said: All the cvt trans are crate rebuild now. Dealerships just swap out the units with the reman. Specialized tools make it too hard for independents or dealers to take it on. Journeys don't have CVT transmissions. 2late4u and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted April 18, 2021 Report Share Posted April 18, 2021 (edited) Post doesn’t say they do. Context. Read 5-6 posts above. Discussion was about Jasper rebuild transmissions and if crate rebuilds were ok versus transmission shops. Cvt is part of the push to crate rebuilds, People also associate weird shifting with cvt’s. So kinda on topic. Edited April 18, 2021 by John/Horace Quote Link to comment Share on other sites More sharing options...
