Shaneh001 Posted January 19, 2021 Report Share Posted January 19, 2021 Will a 2009 jeep compass 2.4 motor be a direct swap for my 2011 dodge journey 2.4 FWD Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 19, 2021 Report Share Posted January 19, 2021 have no idea Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 19, 2021 Report Share Posted January 19, 2021 Only one way to find out..... Quote Link to comment Share on other sites More sharing options...
OhareFred Posted January 19, 2021 Report Share Posted January 19, 2021 I doubt it. Too many modules that are different. Is the compass a 4x4? That will complicate things. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted January 19, 2021 Report Share Posted January 19, 2021 Lots of issues like cvt transmission on some compass models, I believe. It still could fit, auto recycler would probably be able to figure it out. Might have to reuse intake manifold from Journey. LKQ have pretty good search options if you are patient. https://www.lkqonline.com/ Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted January 19, 2021 Report Share Posted January 19, 2021 The 2.4 is a 2.4(engine only, not trans with it). Yes may need to reuse intake manifold. BUT the thing to watch out for is that same emission motor is used. IF you have a Federal Emission model, then a California Emission model will not be a direct replace. The cylinder head and Exhaust manifold is different. I've come across this problem on the Avenger Forum I participate on from many 2.4 motored members. Also don't mix the PZEV version either. There's an under hood sticker that will tell you what type yours is ....stick with that. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted January 19, 2021 Report Share Posted January 19, 2021 So flex plate from cvt engine bolts right up to regular automatic tranny flex plate, no difference? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted January 19, 2021 Report Share Posted January 19, 2021 On 1/19/2021 at 9:07 PM, John/Horace said: So flex plate from cvt engine bolts right up to regular automatic tranny flex plate, no difference? Expand I'd have to look it up, but the crank bolt pattern for the flex plate should be the same if the torque converter bolt pattern is different. So then a swap of the flex plate would not be an unduly hard task. John/Horace 1 Quote Link to comment Share on other sites More sharing options...
