scroller61 Posted February 18, 2021 Report Share Posted February 18, 2021 Hi, I have a 2012 Dodge Journey and I am getting heat coming out of all the vents except for passenger side floor. Has this problem happened to anyone else and if so what did you do to fix the problem? Thank you Scroller61 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted February 18, 2021 Report Share Posted February 18, 2021 Passenger side FRONT or REAR? Quote Link to comment Share on other sites More sharing options...
scroller61 Posted February 18, 2021 Author Report Share Posted February 18, 2021 Front foot vent, no air hot or cold coming out of floor vent. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted February 18, 2021 Report Share Posted February 18, 2021 Could be the heater core or the blend doors. Been discussed multiple times. Try a forum search for no heat. Many answers. Quote Link to comment Share on other sites More sharing options...
scroller61 Posted February 18, 2021 Author Report Share Posted February 18, 2021 I have hot or cold air coming from all the other vents, just not that 1 specific vent. After reading post elsewhere, does not the blend control, control the doors for both floor vents at the same time. Just wondering? Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 18, 2021 Report Share Posted February 18, 2021 no you have seperate blend doors one for each side as well there are two separate areas of the heater core as well from what i have read,google you tube with your yr and dodge journey about blend doors, the passenger side is under the glove box and in a real tight area to get to simple to replace just 2 screws but hard to get to you tube has many videos on this repair,, also befor removing it try tapping on it as you cycle the settings sometimes they get stuck..good luck OhareFred 1 Quote Link to comment Share on other sites More sharing options...
probak118 Posted February 20, 2021 Report Share Posted February 20, 2021 On 2/17/2021 at 7:40 PM, scroller61 said: Hi, I have a 2012 Dodge Journey and I am getting heat coming out of all the vents except for passenger side floor. Has this problem happened to anyone else and if so what did you do to fix the problem? Thank you Scroller61 Is it just the floor vent has no heat to the passenger far side or all vents on that far side ? Quote Link to comment Share on other sites More sharing options...
scroller61 Posted February 20, 2021 Author Report Share Posted February 20, 2021 I have hot or cold air coming from all the other vents, just not that 1 specific vent. After reading post elsewhere, does not the blend control, control the doors for both floor vents at the same time. Just wondering? Quote Link to comment Share on other sites More sharing options...
scroller61 Posted February 20, 2021 Author Report Share Posted February 20, 2021 It is just the front vent by passengers feet that is not letting airflow. Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 21, 2021 Report Share Posted February 21, 2021 it is the blend door under the glove box it not working that is why you dont feel air coming out there do a you tube search for videos on it Quote Link to comment Share on other sites More sharing options...
probak118 Posted February 21, 2021 Report Share Posted February 21, 2021 Scroller61, As 2late4u said once the actuator is exposed, I used a 1/4" philips bit on a small ratchet and a stubby philips screw driver on the two screws. Easy to change but, a PITA to get in there, plan on a sore neck and back from laying on the floor bent like a pretzel looking up. Another forum member indicating after changing the actuator will self adjust itself after a few cycles. deejizzle 1 Quote Link to comment Share on other sites More sharing options...
probak118 Posted February 22, 2021 Report Share Posted February 22, 2021 Too late to edit, I also found using a 1/4 " box and open end wrench with the bit was also useful once the screws were backed out and the ratchet and bit became to long 2late4u 1 Quote Link to comment Share on other sites More sharing options...
