Telematics Module - Integral Locating Pin?
I bought a used telematics module off eBay (supposedly for my 2012 Dodge Journey), installed it but it didn't rectify my no connection issue. I didn't mount it in place, could this be the reason it still doesn't connect? There is an "integral locating pin" on the mounting case, should I have mounted the module before testing it? I just left it hanging by the connectors while I tested if it connected or not. See item #1 in attached photo.  What does this "Intergral Locating Pin" do?  Does this pin close a switch or something?
3 hours ago, probak118 said:
You have nothing to loose by trying...that name sure makes it sound like it is a possibility ? They do the same thing for CO detectors that plug into a wall socket.
Yeah good point.  It's worth a shot before I send it back.
I tried it again.  The pin is only for aligning in the case.
Edited by Howitzer
On 3/9/2021 at 5:46 AM, probak118 said:
If your sure that is the part needed, perhaps it is not working ? Might need to buy new then, just curious what is new worth, from what I read not an expensive part ?
Yes, very expensive... $900-$1000 new at the dealer.
On 3/9/2021 at 6:25 PM, Locosiete said:
I'd also make sure no crud on connections. Who knows what it was pulled from. Could have been exposed to elements. That's the gamble buying used online
Yeah I agree it was a gamble.
2 hours ago, John/Horace said:
I'm puzzled what is the correct part number... the local dealership says its 68222278AA,  yet the above website says it's 68222279AA.   ???
If dealer used vin they would be more accurate. Motor city is $724 for that part plus shipping, so cheaper.
Did wrecker part show the correct part number on it.?
https://parts.motorcitychrysler.ca/p/49391033/68222278AA.html
Yes, I believe the dealer used the VIN.  Funny thing is the 68222278AA number according to motorcity doesn't fit my 2012 Dodge Journey R/T. I wonder if the *******79AA would work just fine, it is a lot cheaper for some reason...
No, it was a different number that the seller said will work in my vehicle.  It didn't work, I sent it back and they refunded the purchase.  Still waiting to be paid for my return shipping (as promised).
