Stop chime when door is open in accessory mode
I work out of my car as I’m an inspector,
when I get to a job site I shut my Engine off and put my car in “ACC mode” so I can use my radio and charge my phone.
some times I’d like to sit with my door open but if I open my door the chime starts going off...
does anyone know if there is a programming feature like the seatbelt warning shut off that I can use to stop the chime in this scenario?
It's annoying me just thinking about that noise- and the only time I need to deal with it is when I'm vacuuming the car-
Do you know if there is a door switch on the door jam that can be forced into the closed position (either with tape, or other more robust method)?
I suppose what I'm suggesting is literally to throw a band-aid on the problem; but if the car thinks the door is closed 100% of the time you're only giving up a few quality of life things- such as having the interior lights turn on when you open the door, or the radio turn off when you open the door on exit. (the radio will still turn off after a few minutes even if you disable to door - open switch)
 As far as turning the 'door ajar/ ignition-on bell' off... I don't know if its possible to 'program it away'- If it's not in the manual, then it's not possible.
