Issues with front brakes over heating
Ok so I'm working on a 2012 dodge journey with the 2.4L and it's FWD. Front calipers were seized solid rotors were warped and pads were worn out. Replaced it all bled the whole brake system definitely no air in the lines. But the front brakes are still overheating. I did notice the pedal was a bit stiff when bleeding them. Lines are not kinked and they don't see swollen. Rear calipers if I crack bleeder open and wait a few seconds fluid slowly comes out. The fronts don't. But when I press the pedal fluid does. I'm at the point we're I'm thinking defective calipers.
