40K on a 2009 AWD
RoadWarrior
Just discovered this site. Very interesting posts! alot of people with similar problems and comments!
I work as a courier so I'm in this vehicle all day! Its an 09 AWD Model I got last summer.
So far I like the vehicle I drive through alot of the Adirondack Mountains it has done quite well so far.
It had brakes at 32K. A power window problem and a AC control panel replaced under waranty.
It has 40K on it and it will soon need tires. The Kuhmo 19" tires have done fairly well but I hope the next set have
better traction. I hope I can get something with a more aggresive tread. The best thing you can buy for this vehicle is
a 2$ blindspot mirror because there is alot of blocked views when changing lanes on the highway!
Transmission acts unusall at times under hard acceleration. I would ask a technician about getting the fluid changed more often
and if there is a synthetic you can use. for it. I hope the transmission holds up!
Gas mileage is not even close to the EPA sticker on the window! I been getting about 19-21 on average.
Over all my time with this vehicle has been good so far. I will report back when I have more time.
I'm buying new tires this week. At first, I was looking for Yokohama Parada Spec-X, but they are not available in Canada in 19". The only good alternative I had are the new Toyo Versado CUV. They are on the market since something like... 1 week! So it will be a guess, but I'm confident they will be better than the Kumho (they are really bad in rain).
Thanks for the replies.. Was told last year that OEM Kuhmo tires where all I could get which may have been the case when the Journey was first introduced but I guess theres other choices now. I know this vehicle has a good power train waranty but when I pass another vehilce it sometimes seems slow to repond and other times it gets up and goes.
Really makes me wonder if its a computer glitch or if its slipping.hmmm? One time it wouldn't up shift I turned off the vehilce then restarted it. Then it was fine! And its been fine ever since. Strange!
  • 1 month later...
