JimmyTheP Posted May 11, 2021 Report Share Posted May 11, 2021 My 2014 Dodge Journey with thr 2.4L engine started running hot suddenly. I was driving home at night in about 80 degree weather and it got up to 226 degrees F. I bled my cooling system today but not much came out. I fixed all previous leaks in the cooling system.. Could it be my water pump going out? Normally I run at 202-208 at any speed. Right now I'm running about 213-217 and it gets uo to 226 when I stop. Only thing I can think of is the water pump going out. Anybody have this problem or a solution? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted May 11, 2021 Report Share Posted May 11, 2021 (edited) Is your cooling fan coming on sometimes? Turn on a/c it should come on right away with compressor I believe. Your leaks meaning the thermostat manifold on side of engine was replaced.? Edited May 11, 2021 by John/Horace jkeaton and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted May 11, 2021 Report Share Posted May 11, 2021 That motor uses TWO thermostats. You say you fixed LEAKS, did you also replace BOTH thermostats? OhareFred and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 11, 2021 Report Share Posted May 11, 2021 also do you have the proper ratio of coolant and water,? did you replace with new coolant? what leaks did you fix before? as mentioned did you replace your 2 thermostats? also as mentioned are the fans coming on at the proper time? after all your journey is going on 7 yrs old might be time to do a back flush and new coolant i just had my 2014 transmission and coolant service done at the dealership,just makes good sense. most water pump problems are leaks as was my grandsons water pump leak on his truck.actually it was a seal leak as most newer vehicle use rubber seals instead of the older style gaskets, but we replaced the pump with a new thermostat as well since it was a 15 yr old truck Quote Link to comment Share on other sites More sharing options...
