tim1 Posted June 3, 2021 Report Share Posted June 3, 2021 (edited) I did two things and have never had a dead battery since. 1. I disconnected the plug at the back of the radio. 2. I pulled the light bulb out of the glove box. While the radio was pulled I noticed the light on in the glove box through a hole only visible with the radio out. The heavy, thick owners manual kept the glove box door tilted out activating the plunger switch to turn the light on. The bulb must be pulled as it appears this miniature bulb is not on the interior lamps circuit but separate. NOTE: The problem most certainly is in the glove box door switch and possibly not the radio. But I wasn't going to connect the radio back up and have another dead battery as it was the middle of winter when I solved this. Had I not seen the glove box light on while the radio was out I would never have solved the problem. Once again pulling your interior lamps fuse may not solve the problem. Pull the bulb and be done with it. Edited June 3, 2021 by tim1 KTM Laranjinha, Summer Solstice, Locosiete and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
dodge lancer v8 Posted July 22, 2021 Report Share Posted July 22, 2021 i had the same problem on my car i fixed the switch ,all ok now. Locosiete and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
KTM Laranjinha Posted December 30, 2021 Report Share Posted December 30, 2021 THANK YOU!!! Since 2010 that I have Battery problems on my DJ R/T...several AGM batteries replaced...and in my case the problem was this light...OMG!!! Thanks!!! Quote Link to comment Share on other sites More sharing options...
Charlton Wilson Posted March 3, 2022 Report Share Posted March 3, 2022 On 6/8/2021 at 5:24 PM, Locosiete said: If you want to keep light you can glue something like a penny where it meets to add a little extra length to push in switch. Assuming you can confirm by lifting the door a hair and seeing if light goes out You could test the light by turning on your phone's camera and dropping it in the glove box and then shutting the door. John/Horace and Locosiete 2 Quote Link to comment Share on other sites More sharing options...
Christine727 Posted March 5, 2024 Report Share Posted March 5, 2024 On 3/2/2022 at 10:30 PM, Charlton Wilson said: You could test the light by turning on your phone's camera and dropping it in the glove box and then shutting the door. I did this week's ago, the casing for that little bulb was melted, so I pulled the whole thing. BUT, still have the issue. I think I hear the cd player running ( never used it don't own a single cd!). Replaced the TPIM too, still having issues. Any ideas? Live in a small town and have been to 3 mechanics, one keeps telling me what it ISN'T, another tells me it's the TPIM, and the other one changed the window switch on the drivers side because the windows, in the front only, rolled down when NO ONE was in the car. Battery charger shows a trickle drain of about 2.4 to 2.5 after an all night charge. Can anyone help?? Trying to buy a house and can't afford to buy another car right now. Quote Link to comment Share on other sites More sharing options...
Dean H Posted March 6, 2024 Report Share Posted March 6, 2024 29 minutes ago, Christine727 said: I did this week's ago, the casing for that little bulb was melted, so I pulled the whole thing. BUT, still have the issue. I think I hear the cd player running ( never used it don't own a single cd!). Replaced the TPIM too, still having issues. Any ideas? Live in a small town and have been to 3 mechanics, one keeps telling me what it ISN'T, another tells me it's the TPIM, and the other one changed the window switch on the drivers side because the windows, in the front only, rolled down when NO ONE was in the car. Battery charger shows a trickle drain of about 2.4 to 2.5 after an all night charge. Can anyone help?? Trying to buy a house and can't afford to buy another car right now. If you have Bluetooth (Dodge term HFM-hands free module) pull the fuse. larryl and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
