Misfire and smoke
When you pulled the coils and plugs, was there engine oil on them.? If I'm not mistaken, they sit in deep "wells. And if the valve cover gasket and well seal leak oil thru can cause a misfire on affected cylinder(s). Also IF so and removing the spark plug(s), that oil would then leak down into the cylinder and would cause smoke as the oil was ignited(?) and passed thru the converter/exhaust.
