Setting a tire bead.
I have done it on my zero turn tires by the twisted rope method, and also with a tie down strap.   Got hit in the face once with the strap latch when I released it.  Learned to wrap it around a few times, and the friction where it crosses over itself slows down the recoil when it is released.  Those tires are so small and wide that it makes it harder than a car tire, I think.
Small tractor tires are really tough, I agree.
ATV tires which have a double bead are the worst for removing, not as bad when setting bead.
Sometimes removing the valve stem internals gives better flow for pushing bead in place.
Tire shops often do it this way.
