TheHammer85 Posted August 31, 2021 Author Report Share Posted August 31, 2021 Thanks rebel...I should Have told you the first time you said it that I will do that next so you didn't think I was avoiding doing that. So im gonna do that asap and on the 17th the shop is gonna take a look again and check the new ecu that I installed. I will report back. Thanks again for everyone's help. 5rebel9 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 31, 2021 Report Share Posted August 31, 2021 actually i dont think the the 2,4 trans has a filter as on my daughters jeep 2.4 the dealership said the filter is not replaceable without dissembling the transmission they just replace the fluid Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted August 31, 2021 Report Share Posted August 31, 2021 (edited) 4 minutes ago, 2late4u said: actually i dont think the the 2,4 trans has a filter as on my daughters jeep 2.4 the dealership said the filter is not replaceable without dissembling the transmission they just replace the fluid It DOES have a VERY easily replaced filter... and rock auto lists the many suppliers with price ranging from $6.00 to $23.00 and If I were to cross reference the part number, it's probably the same filter as used in my past 04 minivans. Edited August 31, 2021 by 5rebel9 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 31, 2021 Report Share Posted August 31, 2021 yes your right the jeep uses a different transmission that doesn't have a replaceable filter without tearing it apart,but the journeys do have one which only makes sense, guess they think they will make more $$ off it i guess Quote Link to comment Share on other sites More sharing options...
