alex519 Posted July 2, 2021 Report Share Posted July 2, 2021 Anyone know where to even start with this its showing I have pressure in my tires so thats working but yet I keep getting this on my dashboard I included a link to the photos https://photos.app.goo.gl/7JGHZ1rbqBodknbe9 Quote Link to comment Share on other sites More sharing options...
alex519 Posted July 2, 2021 Author Report Share Posted July 2, 2021 Quote Link to comment Share on other sites More sharing options...
alex519 Posted July 2, 2021 Author Report Share Posted July 2, 2021 Here's the photos if the link don't work please help me so I don't waste money. Side note it shows tire psi all the way around Quote Link to comment Share on other sites More sharing options...
jkeaton Posted July 2, 2021 Report Share Posted July 2, 2021 Move to the correct section. Sensor batteries are probably dead. OhareFred 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 2, 2021 Report Share Posted July 2, 2021 as jkeaton mentioned battery in the sensor is going bad,sense you dont mention air loss in the tires, any good tire shop should be able to help you, i use discount tire stores for all my work if you have one near you try them out they are great and wil be cheaper than most other places,,, stay away from pep boys Quote Link to comment Share on other sites More sharing options...
alex519 Posted July 2, 2021 Author Report Share Posted July 2, 2021 1 minute ago, 2late4u said: as jkeaton mentioned battery in the sensor is going bad,sense you dont mention air loss in the tires, any good tire shop should be able to help you, i use discount tire stores for all my work if you have one near you try them out they are great and wil be cheaper than most other places,,, stay away from pep boys In all 4 it's reading I have pressure on the tires see Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 2, 2021 Report Share Posted July 2, 2021 TPMS Life Expectancy The estimated life expectancy of an OE TPMS sensor is 5 to 12 years, with the average lifespan being 7 years. TPMS life expectancy is directly related to the number of radio frequency transmissions the sensors make. Driving habits greatly influence the number of RF transmissions a sensor makes in its lifetime. For example: sensors usually transmit when the vehicle is stopped and transmit more often when in motion. Maintaining a constant speed, such as when you're on a highway, reduces the demand on TPMS sensors and allow the sensors to transmit less often. Drivers who often find themselves driving in start-and-stop type traffic will have a greater impact on the vehicles tire pressure monitoring sensors. Weather can also have an impact on tire pressure sensor battery life. Cold conditions allow batteries to last longer. Warmer conditions take more of a toll on TPMS battery life Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 2, 2021 Report Share Posted July 2, 2021 2 minutes ago, alex519 said: In all 4 it's reading I have pressure on the tires see since it is all of them, might be the receiver for the signals then, which will be a trip to the dealership or a garage that handles such repairs or a black section of electrical tape to cover up the warning so it doesn't bother you if you decided to go without fixing it,good luck and report back on what you find out is causing your problem jkeaton 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 2, 2021 Report Share Posted July 2, 2021 Actually, warnings can be set if pressure readings (as shown) go too high for TPMS software program. 42 psi seems a bit high, try lowering down some and see what happens. Sensor battery problems tend to have that wheel position drop out showing press. 2late4u, jkeaton and Summer Solstice 3 Quote Link to comment Share on other sites More sharing options...
alex519 Posted July 2, 2021 Author Report Share Posted July 2, 2021 2 hours ago, 5rebel9 said: Actually, warnings can be set if pressure readings (as shown) go too high for TPMS software program. 42 psi seems a bit high, try lowering down some and see what happens. Sensor battery problems tend to have that wheel position drop out showing press. Lowered it some what is the ideal wheel psi for the 17in wheels? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 2, 2021 Report Share Posted July 2, 2021 (edited) I set mine at 36 psi (COLD), but there is a sticker on the drivers door (or frame) that has the tire and pressure specs for you. NOTE when changing pressures, to get accurate sensor readings you need to drive the car some for things to update and with warnings to be able to be self checked and cleared. Edited July 2, 2021 by 5rebel9 2late4u, Summer Solstice, jkeaton and 1 other 4 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 2, 2021 Report Share Posted July 2, 2021 Further thoughts..... You say you keep getting this message. Did you just rotate tires or get new ones put on? IF so then you still need to drive the carat least 1/2 mile at 30 mph for sensors/ receivers to learn/self check and CLEAR the warning message. Further postings of concerns to a forum needs to have fullest info possible given for good suggestions to be made. 2late4u, larryl and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 13, 2021 Report Share Posted July 13, 2021 From further experience( on saturday) I had a tire sensor replaced on our '11 DJ was there for the whole process of activating the sensor(an aftermarket brand) thru installation back on the car. Aftermarket scanner showed all good, but the EVIC message, pressure reading and warning light did NOT go away until I had driven 1.5 miles at speed. During this time, the warning light would give a single flash about every .3 miles. I believe this was from the system checking position and pressure of each tire as I stated earlier. The system of the car itself HAS to relearn by driving, and not just use of a scanner to reset lights or messages. So on our DJ, we now have 2 new sensors on the front tires and originals on the rears since getting the car. Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted July 13, 2021 Report Share Posted July 13, 2021 Your reset experience is normal for the Journey. I've had more than 1 flat tire to test that out. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 13, 2021 Report Share Posted July 13, 2021 1 hour ago, Summer Solstice said: Your reset experience is normal for the Journey. I've had more than 1 flat tire to test that out. Just putting it in print for the many "guests" that read the forum pages and not ask. OR those that think scanners can do ALL the work, just like it takes driving to reset IM computer monitors when OBDII codes are cleared. Quote Link to comment Share on other sites More sharing options...
larryl Posted July 13, 2021 Report Share Posted July 13, 2021 Had to replace a sensor on mine...it was shot Quote Link to comment Share on other sites More sharing options...
