2010 Dodge Journey keeps draining battery
I have a 2010 Dodge Journey SXT that I bought last June. About 6 months ago, I went out to the garage to leave and it was dead. I jump started it and it took right off. Ran fine for the next 2 or 3 days and then the same thing. I had it towed to the shop and they ;put a new alternator on it. I was told by the mechanic when I went to pick it up that it still wasn't starting right and I probably needed a new battery. I purchased the new battery and had it put in. It went fine for about two weeks and then nothing. All cables are securely tightened. When it does this no starting issue, when I put the key fob in and turn it, I can hear a clicking sound coming from somewhere around the firewall. I am so out of ideas with thing. I love it but I am losing my patience with it. Any ideas or suggestions?
search the forum for ideas as this has been talked to death about, everything from aftermarket accessories to GPS trackers that havent been removed to every other possible problem,,,probally the resewn the person sold it was this problem...good luck and report back if and when you find the solution
 for the next poster
  • 5 months later...
  • 2 years later...
Most common Journey parasitic load (drain while sitting) is the hands free Bluetooth if you have it. There is a mini fuse in passenger kick plate panel. Called HFM I believe, but the 2009-10 are different. Need a multi meter set  it to milli amps and start testing draw. After car is off 3 mins check what draw is on main battery, should be only digital clock and radio presets. So 50-75 ish milli amps.
Mine had an issue where the light in glove box wasn't turning off. Glued a quarter to the door to add a hair more to push in plunger and that helped turn off the light.
Used my phone camera to record a video, placed in glove box and let it record a video for a couple minutes. Checked video and sure enough light stayed on even though dash and everything else was off
So many different kind of electrical draws can be possible that trying to find out on a blog will almost be Impossible, there are so many  components in today's vehicles that  unless you are really good with different meters and know where to look or test,,, South main auto on you tube is a great place for info and lately he has been posting about finding electrical problems with different cars,,,makes my head hurt just thinking about how he can do everything that he does..ALL this said you probably need to find a good electrical mechanic shop  to chase the problem down. Good luck and please report back on what you find for others that will be looking for their odd ball problem with their Journey
  • 6 months later...
Also have battery drain on 2011 Journey. Dealer said it is HFM, wants $1400 to replace it. Said this may fix drain but three other down stream modules may also be causing some drain. Total cost is $1800. Anyone have HSM module replaced and at what cost. Is this a fare price.
https://www.dodgejourneyforum.com/profile/22067-unclesamautos/
This guy seems legit. Have not personally delt with him, but shipping him your dead unit for a refurb is most cost effective repair. The unit is mounted in dash right underneath steering column. Not easy to get at. There are utube links of people removing it. How long is warranty on dealer repair ?
