Glenf88 Posted July 19, 2021 Report Share Posted July 19, 2021 Good day My 2015 crossover abs light and under inflated Tyre light is on. When I pull away I hear a grinding noise aswel when braking. I thought it was pads that needed replacing. But was told that the front abs sensor needs to be replaced. Is that at all possible considering the grinding noise it's making Quote Link to comment Share on other sites More sharing options...
jkeaton Posted July 20, 2021 Report Share Posted July 20, 2021 (edited) You will need to pull the wheel off and inspect. It could be, or it could be something else entirely. You can also get the code read and that should pinpoint the issue instead of guessing. Edited July 26, 2021 by jkeaton Armando G 1 Quote Link to comment Share on other sites More sharing options...
