Glenf88 Posted July 19, 2021 Report Share Posted July 19, 2021 Good day My 2015 crossover abs light and under inflated Tyre light is on. When I pull away I hear a grinding noise aswel when braking. I thought it was pads that needed replacing. But was told that the front abs sensor needs to be replaced. Is that at all possible considering the grinding noise it's making Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted July 19, 2021 Report Share Posted July 19, 2021 (edited) The grinding noise may be a wheel bearing which the sensor is part of. You need to investigate it closer to be sure. Bad wheel bearings tend to be louder with speed or at certain speeds. Edited July 19, 2021 by Summer Solstice NavalLacrosse 1 Quote Link to comment Share on other sites More sharing options...
NavalLacrosse Posted July 19, 2021 Report Share Posted July 19, 2021 (edited) Yes, agreed with Summer Solstice; sounds like a Bearing issue. if it wasn't for the ABS light, I'd normally say the rotor got chipped, or the brake pad is dragging, but the ABS light means the sensor is involved, and that means the Bearing is needing replacement. Im thinking the Wheel Bearing Assembly includes the Sensor and wiring needed. if you swap one, you swap both at the same time. seems to be $100 for the pair online. Probably closer to 200 in store. i'd recommend getting medium-to-good brand, and not the Chinese knock-off, if you can. The TMPS light is on? Check the Pressure levels in the Gauge screen to see if it's coincidence that one of the tirEs just is low on air. The Center display will display the warning with priority first, so when you turn the car on it might just skip the tirE pressure and go directly to the ABS braking system message without telling you the tire pressures. Edited July 19, 2021 by NavalLacrosse Quote Link to comment Share on other sites More sharing options...
Glenf88 Posted July 20, 2021 Author Report Share Posted July 20, 2021 The TMPS light was on. Put air in all 3 tyres that showed it was low ( not the front right tyre) Reset it and it's fine now The ESP light has also been on the whole time aswel. (probably should've mentioned that aswel) The grinding noise is only at low speeds like pulling away and braking as I pick up speed it goes away Quote Link to comment Share on other sites More sharing options...
Glenf88 Posted July 20, 2021 Author Report Share Posted July 20, 2021 Also do you guys know if the part number 5085822AB is the same as Part No 05085822AD RHS FRONT ABS Sensor. I have tried google but having no luck. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted July 20, 2021 Report Share Posted July 20, 2021 These guys hpseem to have the most accurate parts lists and they sell OEM as well. I don't work for them. Have caught other parts stores checking their site as a cross reference. ? https://www.rockauto.com/en/catalog/dodge,2015,journey,3.6l+v6,3309784,brake+&+wheel+hub,abs+wheel+speed+sensor,1912 Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
