lars56ca Posted July 23, 2021 Report Share Posted July 23, 2021 I'm having an issue with unlocking the doors an a 2010 Journey. The odd thing is that I can lock ALL the doors and hatch OK using either the key fob or the buttons on the drivers door but II can only unlock the drivers door. All the other doors and hatch will not unlock. I can't help but think it's not a mechanical issue but rather a programming or software issue. After all, why is it only the drivers door that works properly? Any help would be greatly appreciated. I'm not sure if the battery has been replaced, but if so, does something need to be reset? Thank you Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 23, 2021 Report Share Posted July 23, 2021 Welcome to the forum. Did this just start happening or has this been a long term problem you've put up with? If FOB will unlock the drivers door with one "click", Try 2 clicks in rapid succession to see if the other doors also unlock. This would be a programming thing that you should be able to change to single "click" for all. As far as the drivers master switch on the door, it may be going bad as to why it won't unlock the the other doors. 2late4u and Summer Solstice 2 Quote Link to comment Share on other sites More sharing options...
