Dodge Journey 2010 when I starting the engine doesn't work only clicking
The problem is with the Dodge Journey 2010 2.0crd, when starting it click'ing, the starter doesn't work,
Video when starting the engine:
https://www.youtube.com/watch?v=8-8Gj-uWnXA
The battery is new, the starter is new
After removing the starter relay and making the jumper, the starter works so the battery cables are ok, but the engine doesn't start
What could be damaged?
Sorry for my english ;)
Regards
Edited by bolekf22222
Jumping relay bypasses  safety items in circuit. Key switch security, transmission range selector.
If it's clicking starter is getting power. If you tap starter with rubber mallet it will probably start. Bad solenoid contacts on starter.
Just coincidence relay jumping worked,
